EUTELSAT 8 West B
MCelliotG
Thessaloniki, Greece
Well we'll have to see more reports from the Balkans furthernorth than my location and have a rough conclusion to this beam's behaviour! If I'm in null, that will be so unfortunate!
If you are just outside the official footprint, perhaps you are in a null? Those further away might be seeing a side lobe so the signal will be a little stronger.
Eutelsat 8 West B @ 8 west update
Feeds @ 8 west
12508 V 6975 Europe (S2 8PSK 5/6 Swiss)
12546 V 2267 Europe (S2 8PSK 5/6 France)
12549 V 2267 Europe (S2 8PSK 5/6 France)
12555 V 2267 Europe (S2 8PSK 5/6 France)
12561 V 2267 Europe (S2 8PSK 5/6 France)
12573 V 2267 Europe (S2 8PSK 5/6 France)
12576 V 2267 Europe (S2 8PSK 5/6 France)
12585 V 2222 Europe (S1 fec=1/2)
12613 V 2400 Europe (S2 8PSK 5/6 France)
12647 V 2500 Europe (S2 8PSK 5/6 Italy)
12655 V 5000 Europe (S2 8PSK 5/6 Italy)
12713 V 3600 Europe (S2 8PSK 3/4 France
Archived-1
Persona non grata
uk
Struggling to scan the channels in with this one at the moment on the 1.2 dish I need a little more signal, I will try later.
Laser
Music Channel R101 on European Beam
Details 12655 Vertical 5000
Looks like it may have been there a while but only just come across it!;)
Laser
Anyone get C Band OK in the UK?.. Would a 1.2CM be sufficient?
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
NOT IN ITALY WITH 150 CM AND C BAND AS DUALFEED.
REGARDS
Yep, quite a few of us. A 1.2 CM would only get you very minimal amount of channels on the strong TP's . Ideally for decent worth while results look at a 1.8 minimum or larger if you can.
Laser
Thank you John
adonis1
3807R 3250 5.4 db
3840L 2400 6.3 (photo)
3890R 30000 3.4
3925R 30000 2.7
1.5m dish with TM-5402 HD M3
Lexzie
TBS 5925 USB-tuner
The Netherlands
Is 3840L the strongest signal? I can't find the satellite. (Have only 5W and 20E atm)
satkijker
See Signature.
Mill Netherlands
With CM 180 enSab-Titan Micro.
3807-R-3250 58%
3810-R-2200 40%
3840-L-2400 35%
3859-L-1041 5%
3890-R-30000 53%
3925-R-30000 56%
3958-R-6200 9%
... the Cband footprint for this sat in central UK is on the outer edges. Here is a quick scan from this morning on CM1.8 / AV-Comm poloriser barrel / Zinwell lnbf.
Eut 8° West Cband. ----- Feed / Promo / Test ??
3819 LHC. SR:1100. Fec: 4/5. QPSK. Service ID: "Contribution Test". Provider: Stellar DBS
mar-val
Slovakia,Zilina
Try 3890 and 3925 R 30000. These TPs need low SNR to lock.
Lexzie
TBS 5925 USB-tuner
The Netherlands
3807-R-3250 58%
3810-R-2200 40%
3840-L-2400 35%
3859-L-1041 5%
3890-R-30000 53%
3925-R-30000 56%
3958-R-6200 9%
Indeed I found the bird last night with 3925R. App. 1.8 dB signal! (150cm dish).
I stumbled on another strange problem. I managed to lock and scan 3890R but when I try to tune to a channel I get the message 'Station not available. Check tuner configuration!'
And AFAIK that configuration is correct and is the same for other satellites via the same dish/LNB.
Edit: Don't know what happened, but now it's working fine...
Lexzie
TBS 5925 USB-tuner
The Netherlands
Has anyone received 4153 L? The Multistream transponder? If so, besides the dish size, with which receiver?
And does anyone know if a subscription is possible for these channels?
Can't help you too much on this one @Lexzie, that freq locks ok here on the Promax analyser in North Nottinghamshire (central UK) on a 2.2 PF with an average dB of 10dB. My 6983 pc card won't catch it with the SR of 60000.
