I would like to but no real need for two dishes of similar size, reading up on the make of dish and my minds made up, prime focus it is
Fair enough - personal taste is, well, personal.
More lnb options for prime focus dish
Really? I would think the other way around - more combinations of Ku and Ka feeds matching the 0.6 f/D (or equivalent opening angle) of the CM are available.
and it will perform better than the channel master
Hmm.
What assumptions do you base that on? If we assume that the CM and Precision are both perfect in shape, the CM will have an (ever-so-slight) edge on the Precision.
Assuming the Precision is a true 2.3m (working area), the CM is slightly larger (almost 9% larger area), and has no interference from LNB/feedhorn.
The only point where there might be a difference as at Ka band, where the all-Alu dish might be a better reflector.
So... your mileage may vary.
Only real way to find out is to mount both - one after the other, and then provide proper hand-on evidence to answer the question of which is best!
But of course that's all just small stuff.
Good luck with the new PF - looking forward to seeing that mounted on the polar mount!!
