How to enter legitmate BISS key?
dankargo
Brentwood, UK
90cm Motorised
Brentwood
I have been given a legitmate BISS key to view a feed but its the first time I've ever attempted to on my Vu+Zero box which runs Enigma2.
To construct a line in my Constant.cw file, I need to find out the Video PIDs but for the life of me I can't recall how to do it - as its something I've not done in a good while.
I will not post the key obviously but how would I go about converting these values? I briefly recall having to use a decimal to hex converter in the past.
Any assistance would be greatly appreciated.
You have all the info you require there. 3140 Dec is c44 Hex!
dankargo
Brentwood, UK
90cm Motorised
Brentwood
Thanks AnalogueSat, still no success though :(
I've been entering in this format - is this correct?
2600:000000:753E:013A:0C44:: (followed by CW)
Its been a long time since Ive played with these but looking at another forum on a 5 year old thread the data looks like this for this particular example
2600:000000:17DE:17DE:1FFF::{key entered twice}
where
caid 2600
Prov ID 000000
SID 17DE
PMT 17DE
ECM 1FFF
dankargo
Brentwood, UK
90cm Motorised
Brentwood
where
caid 2600
Prov ID 000000
SID 17DE
PMT 17DE
ECM 1FFF
Thanks AnalogueSat, unfortunately still isn't working. I'm wondering if its simply my box not picking it up.
Have you checked to see if the feed you wish to view is 4:2:0 or 4:2:2 video format?
If it is 4:2:2 format you will not clear the picture with a Vu Zero even if you do have the BISS cw.
Rgds
Please DONT post anything even with fake hex keys in it on this forum. Ive deleted one post that contained such a false key. The forum rules are very clear on this matter - no keys of any kind.
Ragnarok
Samsung SKY HD box
wintv nova-s2 tuner card+Pheonix & infinity USB unlimited
For the future reference and hopefully fully compliant with the forum rules. I used xx's and yy's to represent the CW keys, but they are not keys or even fake keys, as keys are in hex.
my template is where xx marks the would be odd (first 8 xx's or bytes) and even ( last 8 yy's or bytes) control word key in HEX, the biss key including checksum should be 8 bytes and you put it in twice so your xx's and yy's should be the same key,
CAID: PROVIDER : SID: PMT: ECMPID : VPID: xx xx xx xx xx xx xx xx yy yy yy yy yy yy yy yy
was close but not quite
2600:000000:753E:013A:1FFF:0C44: (followed by CW) would of worked
This would of worked too
2600:000000:753E::1FFF:: xx xx xx xx xx xx xx xx yy yy yy yy yy yy yy yy
If you leave out say the vpid or PMT it no longer matters what they are and the emulator will use the key as long as the rest of the info is a match. You can leave out the info you don't know. the more keys you have, the better it is to have more info entered so that key only gets used by the service it's intended for it not always possible and you may have to remove keys to use other keys. Many feed parameters are very similar.
dankargo
Brentwood, UK
90cm Motorised
Brentwood
This helped so much in getting to grips with it, thank you immensely!
WHATAGOAL1
2.4, 1.8channelmaster, tm5402, tech1500, db920
Leic
how would same be for dreambox
???? ???? xx xx xx xx xx xx xx xx yy yy yy yy yy yy yy yy
Ragnarok
Samsung SKY HD box
We are talking about the format of constant cw file in the likes of for EMU's, it's the same format for that file on a dreambox.
but you can replace the xx's and yy's with keys if and when you know them.
Each xx or yy is a byte so in hexadecimal that would be a value between 00-ff in hex.
