maybecrazy
- Jan 28, 2017
- Age
- 71
CM 1.2m with Inverto KUKA, Cahors 90cm 28.2, 19.2, 13.0 east, 0.8, 5.0 west
Inverto Unicable II multiswitch > Ankaro 8 port legacy switch, EMP 8 port diseqc 1.1 switch
VU+ Solo 4k, on order Octagon SF4008
- Midlands
Hi Chris, thanks for replying
Can you not see my screenshot ? I just need to know what to enter in ALL lof settings including threshold, I know the LOF but I'm thrown by the LOF high, low and threshold settings.
I did edit the post to say that I'm using the dedicated KA port, diseqc side of things I'm ok with.
The screenshot shows the default settings for a universal LNB when changed to user defined, I know I need to change parameters.
