Just Sharing This Some items I just came across on eBay LNB HOLDERS USED WITH EXTENSION ARMS (LITTLE WIZARDS)
Spiff
Mullion Cove Cornwall
shopingathome.com
Technomate TM-5402HD M3 C1+ Super+
Primesat VBox
2 x Actuators
Precision 1.3m Prime Focus Dish & mount.
InvertoTwin Black Pro C120
Amiko Viper4K
Primesat VBox
2 Actuators
Precision 1.5m Prime Focus Dish & mount
Titanium C1W-PLL C Band
Seven Computers : )
Two Davis Vantage Pro Weather stations
One Waldbeck Weather Station
Tempted! But it looks more like a buy for CJ, blademedia or even RimaNTSS as they could probably find uses for some of those :p
blademedia
Sky
Been on for a few months now, no use to me tbh, I need to clear lots of stuff out myself.
Thought about it, and so made a £5 bid to "test the waters" as there might be a few things there that I could possibly use - IF the price is right (anything above £12 definitely might not be - but might put a few for sale on here if I "win", get the stuff and then see what I don't need :D ).
£5 bid got refused, then bid £8 and the seller came back with a "counter offer" (never seen that sort of thing before) of £10, and so I bought this load of "whatever" - should be here towards the end of next week and I will be interested to find out what I have actually got!
(I certainly need some new LNB holders for the Gemini as the existing ones are a cobbled-together mixture of very old bits, including some from Amstrad dishes!)
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
Good luck Jeallon01.
Counter offers are the normal thing on eBay, for both buyers and sellers.
You can set an auto except or reject offer price as well, or instead.
You did the right thing to go in very low, Alanna often cringes at some of the offers I make ; 0
Blowing like hec here in Mullion Cove, road signs down, but more important Spiffs dish is still unscathed : )
God Bless Spiff
blademedia
Sky
There was two lots at one point from this seller, I noticed one of the lots had a channel master feed included, £10 is a good price, its something to tinker with :)
... £10 is a good price, its something to tinker with :)
Not forgetting the £7.99 P&P, so £18 altogether!
But thanks to Spiff for the lead in the first place! :D
blademedia
Sky
Its still cheap, think of all the hours of fun you will get from them installing some, many time ive started lnb projects and ran out of parts, that wont happen to you :)
"Fun" - maybe ???
OTOH, it might make some changes and adjustments a little easier for me - and maybe for some of you if I offer some of the "spare" stuff here that I consider that I don't need. :D
blademedia
Sky
If you find a bullseye 11 amongst it give me a shout, my £10 waiting :D
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Congratulations @jeallen01 ! Good stuff for experiments. Unfortunately those plastic holders do not allow to adjust position of the LNB, but you may find exact (original) model for your antenna in that stock. Have a great weekend playing with them.
bm
If that is a "serious" question, I've never heard of /seen one of those - so if you have a photo / link showing one of those, then please post it here and I will see if there is one in the job lot.
If not, then I'll get my arrows ready! :D
blademedia
Sky
bm
Its a four port feedhorn as in channel hopper post above, expensive but quality item, saving my pennies for one
The stuff arrived yesterday - No "bullseyes" I'm afraid :D.
Quite a lot of duplicated moderately useful stuff including several multiple LNB brackets, and a big bag of nuts, bolts and washers = useful "ish" pile of stuff to put in the cupboard, and some of the LNB holders will be used to fix the Gemini when I get around to it
There's also one LNB holder with a throat diameter >40mm - some sort of C-band device?
RimaNTSS
N-E from Riga
@jeallen01 You could actually show the picture of what you got. Just spread items little bit apart :rolleyes:
C-Band feed holders are in the region of 58-63mm from memory, depending on the thickness of the LNB throat that requires clamping.
