blademedia
- Sky
- UK
Some information here about unicable and switching
Unicable + Diseqc switching
At this point in time (still scanning) the list shows 710How many transponders listed ?
Just tried to scan Amos 4W again with the Opensat V8 before I send it back - and all it picked up were transponders on Atlantic Bird @5W - poor positioning!Now travelling West ..
currently on Amos2/3 channel count is at 2032 ..transponders 734..
Final Tally using the factory preset channels
As stated at start of the test ..Thanks for the test, factory preset is not good, best using blind scan
Using the 100 (110 nominal!) cm Triax. Wasn't expecting much in the way of channels, but all I got was "spillover" from Atlantic Bird - same thing happened yesterday when I got spillover from the Badr sats at 26E when, vainly, seeing if I could get anything on 25.5E. Probably just hoping for the unachievable with a dish of this size.What size dish are you using, not much left on 4W atm new bird on its way to this position
Thanks for clearing that up Vipersan, the preset scanning ive found rubbish.As stated at start of the test ..
I was using blindscan ..
but only taking TV and unencrypted..
When I referred to factory presets ..I meant the satellites included in the factory list..
No extras input by me..
rgds
Not sure this has been mentioned before, but has anyone managed to add extra sats to the Freesats? (could not do that with the Openbox because it would only allow C-Band L.O.F.S and I have no C-Band kit).
Yes, easy to add extra sats. I have added a few for the west Clarke belt, as the default list concentrates on the east side.Not sure this has been mentioned before, but has anyone managed to add extra sats to the Freesats? (could not do that with the Openbox because it would only allow C-Band L.O.F.S and I have no C-Band kit).
