Old Precision C120 Ku Feed
I found an old Precision C120 Ku feed today that is a slightly different design to the later version. Would anyone know if there was a technical reason for the change of design, pictures attached?
The old design feed is the crusty red one and it has a longer collar on the dish facing side and the ring of the innermost scalar is recessed in the coller. The more recent design has the shorter collar on the dish facing side and the ring of the innermost scalar is protruding from the collar.
The actual length of the waveguide tube in both feeds is the same, it is the scalar positioning and collar that are different. Over to Channel Hopper/John/Trust1/Other Gurus..... ? :)
Rgds
Trust
Nijmegen Netherlands
seems to me for different F/d ratio
Yes, could be, I did not think of that, it came off an old Precision 1.2m dish. I have feeds from other Precision 1.2m dishes and they are all the more recent design. It may be that Precision changed the parabolic shape of the 1.2m dish at some point in their history of manufacture?
I still have the old Precision dish that the feed came off, I will measure the F/D if I setup the dish again.
Thx
... I'd go for the f/D at the moment.
Drop Julian @ Elite a message with the pics, you never know there might be someone who might identify it, perhaps some old Precision staff ?.
blademedia
Sky
I would go for a new design to help prevent water down the throat to lnb,
... they come with a small domed cap usually, have you got one at hand MB to show ?.
blademedia
Sky
Yes small plastic cap John, but look at the design, the older first one is encouraging any water droplets straight to where you don't want it, with the newer type its diverting it.
Its certainly not FD I have three here from three different sized dishes and there all identical.
View attachment 103967 View attachment 103968
Yep that's them, just been having a ferret to find mine, going OT a bit but came across another old thing from the past ... the good old EBU Descrambler.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Similar feedhorns I found on old SMW LNBs
Good old stuff John, while I was looking ive found my de/polarizer, I will be needing this shortly.
Brand new as well matey, they look lovely. Iv'e a couple that i kept for prosperity but mine are a bit more battered lol :)
blademedia
Sky
I do have the battered type somewhere John, I don't like using the new stuff unless forced, I'm a bit of a magpie :-lol
Rgds
Gurus :-lol
Many Precision dishes were supplied for non-satellite reception, installed in radomes for point to point communication. My guess would be the red feed is designed to reject spurious scatter that enters the radome after being reflected from nearby objects. The signal source is going to be no more than 20 miles away and therefore diverging (slightly), plus it will be affected more by low altitude atmospherics along the entire transmission path.
I could be completely wrong though.
The Filmnet one was better.....
Trust
The old red Precision feed with the recessed central scalar was used on a Precision dish for satellite reception. It was part of a setup that used a KHM-36RL motor and a Ku band LNB. The KHM-36RL motor had the strange declination adjustment that used a pipe fitted at a non vertical angle to a circular steel plate. Rotation of the plate adjusted the declination angle, pics attached.
Rgds
blademedia
Sky
That's a nice motor, I have the same one somewhere, also have this tracksat that's similar
blademedia,
Yes, the tracsat looks a very similar motor.
What size aluminium centre focus dish do you think these motors would be OK with, they look to be well built, possibly more powerful than a standard Jaeger 1224? I have attached some pics of a new one that was sold on another forum for €350
Rgds
