Amos 7 (was Asiasat 8) 4W
ocean04
Vaasa
Western Finland (63N 22E)
4W blindscan now, Western Finland, 2.4m, Solo SE signal db
10722 H 27500 10.4db
10722 V 30000 13.1db
10758 V 30000 13.1db
10759 H 30000 9.6db
10805 H 30000 10.0db
10806 V 30000 11.6db
10842 H 30000 8.3db
10842 V 30000 11.6db
10889 V 30000 14.0db
10907 H 15000 9.2db
10925 V 30000 13.3db
11031 V 27500 9.0db
11102 V 30000 9.3db
11053 H 8518 8.1db
11062 H 4500 6.2db
11067 H 3000 6.3db
11139 H 30000 13.2db
11175 H 30000 13.6db
11222 H 30000 14.2db
11258 H 30000 13.8db
11304 H 13333 13.1db
11315 H 5000 13.1db
11358 H 2500 13.0db
11425 H 30000 14.6db
11542 H 3700 14.9db
11610 H 3600 13.2db
11627 H 15000 14.9db
12315 H 15000 12.0db
Several other transponders under lock (atleast for now..)
88cm mesh dish
blademedia
Sky
I can see 10842 H,11176 H & 12315 H on the Spectrum Analyses graph but no lock here on these,
Scanned the empty part of the Ku band here @ 4 & 5 west just in case o_O (11700 to 12500) only showing 12315 H showing but no lock.
12315 H is a new mux listed on flysat
I was able to get 12315 H when it 1st started then a couple of days later someone decided to move the beam to the North Eastern part of Europe :eek:
Several days ago:-
VodzigorLans
Setup is down atm
RU, Saint Petersburg
I doubt it is CEE beam since i can read that people in Ukraine also complain signal was downgraded.
Ive just seen some peaks at previously used Amos-2 tps. It is up and down every almost second, I had to move to 3W for clear picture. No idea what that means.
10842 H 30000 back now on the 100cm
The signal that I have now at 4.0 W,whether it is Amos 2,Amos 3, or Amos 7. 11541 H and 11609 H is definitely on Amos 2.The variation of the signal throughout the day and night is quite high that they will have to move to Amos 7.It is actually the effect of the inclination @hvdh spoke on this topic.At least that's the most logical move of all transponders that are active currently at 4.0 W.But of course that our logic does not match often with the provider.
For those who want to compare the signal in different areas of Europe,I post SNR that I have on each transponder received,especially as I'm in the central of the spot.
VogzigorLans said:
...Ive just seen some peaks at previously used Amos-2 tps. It is up and down every almost second, I had to move to 3W for clear picture. No idea what that means.
It mean a new program TV-Hir TV:11652 H,3332,5/6,Dvb-S/QPSK
100cm
Some that I cannot get may be on this beam ?
WaferSat
Laminas OFC-1200P, 30w-46e
Southern Finland near Helsinki
Hi Ocean, Also in Finland, Southern coast, 50 km East of Helsinki, snowing and 121cm dish
10722 H 27500 8.2 db
10722 V 30000 8.1 db
10758 V 30000 8.0 db
10759 H 30000 8.2 db
10805 H 30000 7.6 db
10806 V 30000 7.8 db
10842 H 30000 8.7 db
10842 V 30000 8.1 db
10889 V 30000 7.8 db
10907 H 15000 9.1 db
10925 V 30000 7.9 db
11031 V 27500 --
11102 V 30000 --
11053 H 8518 --
11062 H 4500 --
11067 H 3000 --
11139 H 30000 8.6 db
11175 H 30000 11.4 db
11222 H 30000 10.6 db
11258 H 30000 10.1 db
11304 H 13333 9.8 db
11315 H 5000 9.1 db
11358 H 2500 9.9 db
11425 H 30000 10.8 db
11542 H 3700 --
11610 H 3600 --
11627 H 15000 --
12315 H 15000 --
/Wafer
VodzigorLans
Setup is down atm
Im sure it was a feed for HirTV, i saw similar one previously at other tp at Amos2 11556 or so. If you need a k#y for that feed let me know since they use a static one.
ocean04
Vaasa
You should also get 11627H 15000, it's big signal.
Most likely 11053, 11062, 11067 and some others are middle east.
Attatched screenshots 11062, 11067, 11031, 11102
WaferSat
Well, at least not in this weather :-( I check another day when its clear sky :)
11386 H and 11393 H-two CZE feeds
Data stream 11156 H 2720 from 5 west
I looked at your avatar, and to tell you the true,wow, it's unbelievable reception MiddleEst spot in the northern part of Europe with 2.4 m antenna, so more if we look to MiddleEast spot regardless if comes from Amos 7 or Amos 2!Could you tell me what SNR you have on this spot during a day/night?I'm sure many enthusiasts,at least on this forum,would be interested to receive this spot.In the southern part of my area this spot on Amos 2 was picked up with a dish at least 3 m.These were the reports from a few years ago,I do not know how it is now,that's why I am surprised that you receive this spot.Congratulations.
amos 3 and amos 7 mid east beam
3.7m
two tp I got from Europe beam amos 2
Amos @ 4 west = SQ in dB
10722 H 27500 = 7.3
10722 V 30000 = 9.2
10758 H 30000 = 8.3
10758 V 30000 = 9.3
10806 H 30000 = 5.5
10806 V 30000 = 9.1
10842 V 30000 = 9.2
10842 H 30000 = 9.1
10889 V 30000 = 10.1
10907 H 15000 = 6.9
10925 V 30000 = 9.9
11140 H 30000 = 0
11176 H 30000 = 4.5
11425 H 30000 = 0
11542 H 3700 = 0
11610 H 3600 = 0
12315 H 15000 = 0
TM5402HD M3 + 100cm Gibertini
Laser
Interesting to read William-1 results above. Some seem (not sure) still to be on Amos 2. As signal shows no change...Reception here is very similar. However I do notice the further west you go even slightly the SQ drops v quickly.....Others have a very large signal on European Beam. Example TVH now showing 90% SQ with 12.4 dB. I guess things will settle down!
