- UK
Thanks nelson, sure you will get round to it, springs not to far away![]()
I got my daughter a pogo stick a few weeks back.
i can see 7 west ok without moving it .... can,t see anything from Nilesat 201 though ...
i can see 11595 V 22000 from E7WA , its listed as being on the NWA beam ... i,m sure it is looking at the signal db.... its a first for me i think..... the ME-NA beam is strong.
Easily comes in on my CM 1.8 BladeHi nelson, what signal are you receiving from this with the 2,4 and does the 1.8 lock it, could you check with the v7 please
Hey Nelson, any chance of a quick try on 36e Russian beam on the 1.8? I still haven't tried the plate you sent but hopefully over the next few weeks.
It's for sure NWA. (MENA is bad here)I think this is from the Mena beam ? not NWA its far to strong compared to other NWA transponders.
2.4m and Solose. Currently light rain..
10992 V 5000 12.4db
11034 V 5000 10.2db
11170 V 5000 11.5db
11476 V 27500 8.4db
11559 V 27500 8.2db
11595 V 22000 7.8db
11658 V 27500 9.8db
For comparison:
10719V 22000 6.0db
11938V 27500 8.1db
Took advantage of the sunny weather to try this with a plate. This time, all the Russian beam frequencies you receive come in at about 2.5dB - obviously waaay below what's required for lock. I have a better chance of 56e down here but not until I relocate the dish slightly... and that probably won't be enough.
.. the plate i sent you is as good virtually, as an original one too - only 0.1 db less on my setup. Yeah it doesn't help the fact that there are sub-Sahara beam transponders on nearby frequencies creeping in. I put the LNB at a 45 degree angle to try and eliminate them but with the plate in, it seems to come in on both polarities. Is that the best position for the LNB?
