Just Sharing This Fixing a warped 230cm Dish
satmania
Tiger receiver. FUJI lnb. skystar usb hd pc card
Beghazi Barqa Cyrenaica
how to fix a warped dish?
i have added some iron supports between the dish and mount ring with six strings running across the face of the dish to see which edge is warped, after that pulled the warped edge by iron support and bolt it fixed now the dish is a spun dish
some pictures before and after modify the mount ring
satmania
Pics
here gap is 5mm maybe more:D
satmania
blademedia
Now the dish is spun dish, but as i told you it is standing on its edge instead stand
blademedia
Sky
blademedia
Thanks for the pictures satmania, do you have pictures of the mount please, also a full picture of the dish face I would like to see where the LNB arm holes are located.
satmania
The arms are on edges of dish these are made of aluminum :)
Do you know which make / model ?
mar-val
Slovakia,Zilina
I can be Bulgarian Pasat.
No, do you know model? i will be thakful if someone informs me
It is similar to Pasat, but nothing like their current range of mounting options
If you can post images of the feed structure it will help.
It is using a similar rear metal structure as DH Antennas had in their designs but the polarmount looks very - East -European (paint /no zinc galvanising and large welds). It is a very functional looking unit though if the reflector can be ironed out.
blademedia
Sky
We can rule DH out. they use flat bar for ring not tubular, arms fixings are holes on dish face, interesting dish
I did use the word 'similar'.
DH as far as I recall dont make a 2.3m.
satmania
Many thanks to try help now the weather is rainy, tomorrow will be there more pictures :)
mar-val
Slovakia,Zilina
Also Famaval made 230cm dishes, it has similar holder as on the picture in first post.:rolleyes:
satmania
Some pictures for face of dish with arms and mount similar to what i have.
John and blademedia
Thank you for advice, i have painted the dish by using a sponge type roller
