Hotbird 13e ONLY 660 channels!!???
Steve Coombs
Technomate 80cm, Technomate LNB 1output, TM-5100 Receiver.
Hotbird 13.0e
London
I am trying to install a Sat and receiver, basic details:
Hotbird 13e, 80cm, Technomate LNB 1 output, TM-5100 receiver.
I spent a while with a sat finder positioning it and feel Im not far of as I am picking up 660 channels and signal and quality is good (high!).
Although the channels I really want (Polish) are not all there.
I figured 660 wasnt bad but have now been reading there are over 2000 channels on HB 13e so feeling a little disappointed.
Could it be the receiver?
I have a feeling it is the vertical channels that are missing, but not all by any means.
Mickha
North West
Can you please post the names, frequencies, and other details, of the channels you've scanned in.
There is a possibility that you're not on 13E but tuned to a different satellite.
Please check the links, and the FTA channels you can view:
https://www.lyngsat.com/Eutelsat-Hot-Bird-13B-13C-13E.html
What scanning mode did you use?
If there was a pre-existing stored Transponder list, it's bound to be out of date.
Best to do a Network scan or Blind scan.
Steve Coombs
Hotbird 13.0e
London
I have selected 13e from the sat list on the box. Assuming it knows all the frequencies..?
However looking. At the technomate website the latest software available is 2012, could this suggest it doesn't know all the frequencies?
The channels it has found are in line with what it should find from hotbird so thinking I'm pointing to the right place.
How many hotbird channels do you think I should get?
As stated, if you scanned a pre-stored list, it will be out of date.
Select instead Blind/Auto scan and see what you get then.
Yup you need to replace the receiver. The main Polish stuff went DVB-S2 only recently as my colleague has mentioned.
You can get reasonable receivers for a few tens of £/Eu now
Archive7
If you are after Polish channels, I would recommend ordering a great little box that comes with one month subscription for many channels and has an additional terrestrial tuner (Combo). You can extend the subscription afterwards.
Don't order it with the yearly subscription option (under prolongation). Let them activate and test it for you before shipment. You will lose few days during transport and delivery but will save you plenty of headache to get it activated outside Poland.
https://satsklep.pl/en_US/p/NC-Telewizja-na-karte-with-package-Start-with-receiver-ADB-2849ST/19936
Of course it will also scan other satellites up to four with a DiseqC.
The menus are only in Polish, but I am sure you will manage with a little help.
Edit:
They have new offer with receiver with 500GB and also combo. Slightly more expensive.
https://satsklep.pl/en_US/p/NC-Tele...ackage-Start-with-receiver-PACE-HDS7241/35903
Steve Coombs
Hotbird 13.0e
London
Ok. I thought it might be the receiver on Friday so I ordered a box which has come. Hd. And branded up with nc+.
Wish I read the advice about activating before shipment. Anyway. Can get it activated tomorrow morning.
Should this work straight away after activation?
Does this explain as well why the channels didn't show up on the list on my standard box?
Archive7
What is the receiver exact model number and what do you mean by branded with nc+?
Steve Coombs
Hotbird 13.0e
London
It worked.
New hd box worked a treat.
For any future polish sat buyers in U.K. 80cm dish and goto eBay and get a polish box and free trial for a month!
Take the advice of the person above and have the shop activate it and test!!! Saves the waiting!!
Archive7
It worked.
Good.
What is the exact model number?
