Advice Needed Help needed
David moss
I've got a openbox v9s it's set up for sat but I want to change it to vm cable
Wigan
Hi can any help me I've got vu ultimo on sat but I want to change to vm any one know how I go about it thanks
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Hello David, welcome to the forum
So correct me if I am wrong you are asking us how to swap from a satellite setup to VM, but what do you mean by VM? Virgin Media, VMware or something else?
Hi David, welcome to the forum. VM presumably means Virgin Media so first question - does it have a cable tuner in it? If not forget it.
David moss
Wigan
Virgin media
well it's only got one tuner in it would it need flashing with a vm image
If its not got a cable tuner in it you can flash whatever image you like on it - it wont work. Different tuners, different frequencies. If it supports pluggable tuners you can buy aftermarket units to swap it over
David moss
Wigan
It's not pluggable tuners thanks for your help and honest advice could I change my vu ultimo from sat to virgin that has 3 tuners init
Mickha
North West
According to the VU+ home site the VU+ Ultimo has Plug & Play tuners, so you can plug in a Cable tuner, available for around £60, and then change the cables.xml file for one suitable for Virgin.
http://vuplus.com/sub/sub0106.php
The tuner is a DVB-C/T2 Single Tuner, suitable for the Uno, Ultimo, Duo 2, Solo SE, Solo SE v2, and Solo 4K.
If it's similar to the Duo 2, you can run satellite, and cable, tuners, side by side, and view both satellite, and cable.
daro2096
No setup at present
Consett, Durham
Isn't there a twin tuner DVB-T2/DVB-C module available from VU+?
Mickha
North West
Not that I know of, but as some VU+ models have at least two tuner slots, like the VU+ Duo 2, you can fit two DVB-T2/DVB-C modules, but you do lose your satellite option.
Equally there are external USB tuners, that can be fitted, to allow extra viewing options.
Tururu
Assembled with recycled parts
Recycled as the owner.
VU+ ???? What a model, good question.
DVB-T2/C ????
Normal.
VU+DUO2.- 2 normal slot
VU+Solo4K/Ultimo4K.- 1 normal slot
Single and double DVB-T2/C (1/2 tuner)
FBC.
VU+Uno4K: 1 slot FBC
Supports DVB-C (FBC) 8 tuner.
Mixture.
VU+Ultimo4K: 3 slot (A/B/C).
Slot A.- FBC
DVB-S2/FBC DVB-C (8 tuner)
Slot B.- FBC DVB-S2/FBC DVB-C (8 tuner)
Slot C.- normal DVB-S2/twin DVB-S2 /normal DVB-T2/C /TWIN DVB-T2/C
Apart Tuner VU+DVB-T/C/T2 USB TURBO.
