multi lnb holder for laminas 2.7 dish
oldfart
laminas 2.7 offset
Invacom Quattro LNB
Chayofa, Tenerife
DM8K
Tenerife
Don't know if its possible
dish tuned to 28.2E
I would like to get 19.2E and 13E by adding 2 LNBs
may be too far separation?
Any pointers
1. is it possible and if so
2. where to get the holder
AFIK Laminas only produce a multifeed for their 1.2M dish. Anything over this and you'd either have to modify a proprietary bracket or manufacture your own. However don't these two satellites come in fairly strongly at your location? Is it not possible to install a smaller dish (with bracket) alongside the large one?
What kind of LNB you have installed in the focus of that dish? Could you show couple of pictures? I think it is possible to make multifeed. I was on one roof some time ago tuning Lami 2.7m.
signal comes boomimg in here, just wanted to trash 2 dishes on my roof.
I think it is more than possible to make multifeed like that
Of course, original feedarm will not be modified.
I've made a little model of that multifeed. Imagine that piece of plywood is the feedarm. From the right side, in the same way another holder can be attached. Horizontal bars can be longer so they can hold couple LNBs each. And, of course such a nice dish deserves all parts to be INOX :)
