- Jan 7, 2009
- Age
- 58
- Some SAT-related hardware.
- N-E from Riga
A bit off topic but after a bit of advice, is this worth an 180 mile round trip, the dish is free I just have to dismantle it
All i know is its a 2m dish and thats it
Does anyone know what it is?
@gap30 Seems that you will have nice sightseeing 180 miles trip over the weekend And you will need a trailer for that journey. If I were you I would not bother adding another 100 miles, as 180 is more than enough
I don't know what it is but there's a bit more detail here. Are you sure it is 2m? It is hard to get a scale due to the oblique views. Standard bricks are ~225mm including 10mm for mortar and, using that as a scale, it doesn't look like 2m but the perspective adds confusion. If that is 4.5" gutter, the pole looks like 3-4"
More importantly is it worth driving 90 miles there and back for
No, leave it where it is.
What makes you say that?
Is it not worth the trip in your opinion
It looks like a 1.2 mtr dish I forget its name atm, from reading they don't perform two well, you can pick a 1,2 channel master dish up for £40 ish
The same advert has been on eBay for a few days now. I would have mentioned it if it was local to you.
Not sure about the receiver, but motorized CM 1.2m is very good choice. Congratulations!Just bought this:
That's nice @gap30, no don't through the receiver away its ok,
Unsure if you get V box with it if not you will need one, the polar mount looks good and see you have a actuator a c120 and invacom lnb nice setup, post a few pictures up when you get it home.
I wouldn't mind that box , what you gonna charge for it please ?
