rai tested 4k 13e
12577 H
DVB-S2/8PSK
HEVC 27500 2/3 RAI w
Rai 4K w F 6011 6011 Ita
6013 Ita 1601
HEVC/UHD
MCelliotG
Thessaloniki, Greece
Amazing, here's a screenshot!
WHATAGOAL1
2.4, 1.8channelmaster, tm5402, tech1500, db920
Leic
just put this on, am I seeing actual 4k?
dm900uhd and just a normal Hd TV?
MCelliotG
It is actual 4K (I downscaled the screencap).
Tururu
Assembled with recycled parts
Recycled as the owner.
De momento tiene un BitRate "normal", como otros canales el TP, 23Mbs, maximo 26Mbs.
At the moment it has a BitRate "normal", like other channels the TP, 23Mbs, maximum 26Mbs.
En Hot Bird tenemos mas canales libres emitiendo en abierto para ver la calidad de la imagen.
In Hot Bird we have more free channels broadcasting in open to see the quality of the image.
Sports events look great, the same image in HD does not look as good.
For years I like to play with these channels.
Los eventos deportivos se ven muy muy bien, la misma imagen en HD no se ve igual de bien.
Desde hace años me gusta jugar con estos canales.
Foto del VU+Ultimo4K "Cambios_09_06_2017_1930.jpg"
PS: DIGITALBITRATE : Le debit des chaines en numerique - EUTELSAT HOT BIRD 13°E - 12576
Tururu
Normally the receiver can convert the video to 1080p.
You see the channel, but it does not have the same quality.
Normalmente el receptor puede convierte el video a 1080p.
Ves el canal, pero no tiene la misma calidad.
signal sart again
3 july trasmited again
Monday, 3 July will be an important day in the history of Italian television, at 21 on Rai 4 k (channel 210 tivusat), you can explore the wonders of Venice in the company of Alberto Angela, in a long journey into the technological future of television: 4 k with the addition ofHDR (High Dynamic Range), which enables the highest quality images, increasing the range of lights and colors , giving an extraordinary fascination at images.
The advantages of 4 k HDR -more detail, strong sense of depth and realism. With the 4 k – HDR eventually catch every little detail, making a whole new feeling of involvement. More detailed images, brighter colors, four times higher resolution of high definition, to immerse yourself in a truly unique television event. Viewers with compatible TVs will experience an unparalleled viewing experience: the discovery of the beauties of Venice night dimension with an an absolutely immersive as that allowed byHDR.
"Tonight" will be published in 4 k-HDR by partnering between Rai, RaiWay, tivùsat and Eutelsat satellite that has provided the resources and the technology infrastructure at the outskirts of the French capital Paris Rambouillet teleport.
