RimaNTSS
Some SAT-related hardware.
N-E from Riga
Don't mean to interrupt RimaNTSS clearing out his storage
Do not worry about this Sten, I have no problems if I store something for a longer period of time.
gap30
technomate 90cm dish
Liverpool
OK the pics as promised @blademedia @RimaNTSS
Dish jetwashed
Polar mount filed, cleaned, wire brushed 3 coats of hammerite, stainless steel fixings
Wall brackets/pole filed, cleaned, wire brushed 3 coats of hammerite
The only things i have not replaced are the lnb/lnb arm screws and the threaded rod with the markings
I have set the mark on 53, not sure how i set the higher mark :/
@mariust5 i got ya box here
images are too large
Use Pix Resizer ... small but easy to use Windows Prog.
Edit: Ah, you've got it sorted somehow :)
gap30
Liverpool
I might need some help setting this up, i have set my threaded rod to 53
Latitude just over 53 declination 29.3°- 22.6 OS = 6.7
Is this correct?
Latitude: 53.4618°
Longitude: -2.9659°
Satellite: 0.8W INTELSAT 10-02 | THOR 5 | THOR 6 | THOR 7
Elevation: 28.9°
Azimuth (true): 177.3°
Azimuth (magn.): 179.3°
Sounds about right for Liverpool
s-band
Essex
archive10
Its a 1.2 just spoke to him and he wants £40 for it, bargain
Satellite dish | in Cumbernauld, Glasgow | Gumtree
@mariust5 I have not had a chance to post your box yet been up the wall the last few days will try and post tomorrow
It says 20 now. Even better deal now.
But why the wrong 1.85m dish size? Seems rather a lot even with some margin for errors...
(I once saw a local ad for a 1.5 Echostar - turned out to be a 1.2, which is 1.35 at the furthest!)
RimaNTSS
N-E from Riga
Interesting motor !
It is old motor- actuator for changing LNB's position to catch different satellites (instead of moving the dish). Yes, interesting .... as part of the history of SAT-TV.
Oh blimey, a blast from the past!
Digging in my box of memories...
Pipedream
Sheffield
Yes, nice find and with the polar mount too. In the middle of nowhere though!
archive10
This looks like a nice 1.8mt dish for anyone in the East Anglia area
Satellite dish | eBay
Very nice.
With original polar mount (matches the period decal on the dish - this is authentic!).
Unless the dish suffers from flaking (some early CMs did), it's just a clean-up with some soapy water on the reflector, and possibly a bit more rust removal action on the mount (lot's of how-tos on the site), and you've got a premium class feed-hunting dish....
Too bad East Anglia is more than 3-4 hours away by car from here. ;)
s-band
Essex
Very nice.
Less than an hour from here though;-)
Yes, I could do that in less than an hour. Would love that one here, but no spare space unfortunately, unless I remove two fixed dishes first.
The problem then would be restricted scanning area, 30E-40W at most in that position, so not really worth the effort of installing it. Shame.
