BulgariaSat-1 @ 1.9E
First test carrier... 12456 H and 12510 H
12510 H quite strong here as well. Looks like a wide (54 MHz) transponder with two bumps, or two simultaneous ones?
cybertomanek
Laminas AS-1500 +Jaeger SMR 1224 80E - 45W
U2C Denys H.265
Poland
Hey guys, any TP details are available like SR?
It will just be unmodulated carriers at this stage.
John Pykett
Persona non grata
Dish setup: 80cm Motorized Dish, TM-5402 HD M3. This setup goes from 1w to 28.2e
My computer setup: AMD Athlon II X4 645 3.10 GHz processor and 8GB of ram. Graphics Card is NVIDIA GTX 750 Ti. OS: Windows 10 64 Bit
Hucknall, United Kingdom
so what sized dish is required to pick up this sat in the uk?
If you go to post #7 in this thread you will find the maps,
The Central Europe Map includes the UK states a 52dBW so a 45 cm to 60 cm dish will be big enough.
John Pykett
Persona non grata
so in theory a sky minidish will work right?
The Satellite is in place and has already conducted tests on spectrum 12.50-12.75
it look high band wide beam
A lot of interference from other transponders @ 3.1 east 12562 H 13000 data stream.
No test carriers observed atm.
tempo
47.5N, 42.2E / Russia
The testing is active during last 4 hours.
Registered central frequencies of transponders are:
12285V (3 days ago)
12495V (3 days ago, probably beacon)
12188H
11957H
12437V
12209V
12399V
12157V
12252V
There were also many other frequencies that weren't registered precise at the moment of testing, they can be estimated by the spectrum scale.
tempo
More pictures
tempo
More pictures
Transponder testing @ 12400 to 12500 Vertical moving up the frequency scale as I observed it I have never seen this type of activity before.
Test carrier 12475 V
tempo
More pictures since my last post
tempo
More pictures
tempo
More pictures
tempo
Pictures from today
tempo
More pictures
