Archive-8
Got my ka/ku combo on the 1.5 dish, is 7°E still king the same signal levels?
The loudest thing I found was 0.7W 20017R 45000 8/9 16APSK but presume you are looking at band D? If so the only scan I have is this one from 16E H. I can't work out if it was on the 1.5m IRTE or the 1.2 Prodelin.Got my ka/ku combo on the 1.5 dish, is 7°E still king the same signal levels?
The pc is the next thing I got to setup, as had to build a new machine a little while ago.The loudest thing I found was 0.7W 20017R 45000 8/9 16APSK but presume you are looking at band D? If so the only scan I have is this one from 16E H. I can't work out if it was on the 1.5m IRTE or the 1.2 Prodelin.
Edit: Ignore me, I answered a question that you didn't ask. It'll be interesting to see your scans.
... @Chris1979 , do you want me to do a scan of 7°East Ka on my 1.25 Gibby / Inverto set-up Chris, can do no problem squire
A quick grab of 7° East Ka Chris. Is there anything in particular you want me to look for
View attachment 108541 View attachment 108541
It looks like you have a couple of things to sort out before attacking the arc tracking.
Why is vertical almost 10 dB down on left in places? It suggests something amiss with the LNB.
You have a significant slope to the HF end. Is it the LNB or the cable?
The straight line on the vertical scan indicates that you don't have enough gain to overcome the noise in the card above 22.1G, vertical especially but horiz is also marginal in the dip.
Aren't you clocking Bantamba TV on 21568H, chaps? Next to 21571H TPA.
OK with my TD88 dish+XMW LNB.
