Help Required Easy Blind Scan - paid version
Archive-8
I am trying to find the last version before it went to freeware.
Can anyone help me please.
I need the 64 bit windows 10 compatible version.
Thanks.
I have 14.0.0.4 if that works?
.. i have 13.2.0.1 64bit as used on Win7 Pro, but not sure if it's w10 compatable
Archive-8
I have installed it fine :) but it still comes up with freeware version.
Anyone know how to edit this so I can input my paid details?
pontiend
Contibruter
south yorkshire
The option to register may be under the help tag Chris.
My registration is under there.
PrvtN00b
2.4 PF, 1.8 Raven Offset and 1.2 offset for DTV
Panama Central America
For some reason Chrome is telling me that this version is infected and cannot be trusted.
Thanks.
s-band
Essex
You may need to clear out all references to EBSPro & Cjcr etc from the registry. Not quite the same but did you see this thread? EBSPro Activation problem After the author fixed his servers my paid for copy could be registered again.
@Chris1979 : Regardless of whether it says freeware or not, does "About EBSpro" mention the correct version? And did it fix your DiSEqC problem?
@PrvtN00b : I get no results with both McAfee and Security Essentials. Anyway I'll remove it now.
Archive-8
Not able to check at the moment as I have no dish set up now, as halfway through installing the new motor.
Cjcr_
standard
Spain
Hi @Chris1979, you can download the version that you want using the SmartUpdater tool (EBSpro -> Help -> Check For Updates -> More -> Show me all versions). You don't need to put your license details. Old versions will work as full version if you previusly installed EBSpro >v16
Good luck!
