Just Sharing This Crazyscan Updates
Useful. Just need to find a TP with that high a SR which I can resolve with my cards etc.
might be able to help you there Llew ..... @scopus Chris, pass on that Ku TP info that Roy sent you matey
Roy Carman from Feedhunters found these over the last couple of weeks Llew on 34.5W
11.044 V 61966 2/5
11.105 V 61966 2/5
11.075 V 62028 S2 8PSK 3/4
All seem to be data channels
Might be worth look there?
Transponders with symbol rates above 45,000 are mainly used for data,
Some feeds have been observed with S/R over 60,000 but these are very rare.
FlySat Hylas 2 @ 31° East
ABS-3A @ 3° West
11150 V
NS3 68571 Auto EBU Hypermux
SES-4 @ 22 west
12712 V
DVB-S2/16APSK
ACM 46990 5/6 Data
Telstar 11N @ 37.5° West
12712 V
DVB-S2/16APSK
ACM 46990 5/6 Data
Thanks guys. Can't do the NS3 one William, That's Feedsatdxer's territory ;)
s-band
Essex
34.5W 11075V, not locking. The other TPs mentioned above on this bird obviously not up at this time, as they fall within this frequency's spread.
TBS6983
s-band
Essex
A new version of Crazyscan2_1.0.2.150
- Extended DVB-T2 specific signal info in Carrier Search dialog.
-StreamReaderEx-BDA 1.2.4.48 and newer required !
And new StreamReaderEx-BDA 1.2.4.50
-Extended DVB-T2 specific signal info from SignalInfo2(), AirScan().
-SEARCH_RESULT2 struct extended, required recompilation for applications !
When I did an LNB test recently I found that both CrazyScan and EBSPro gave lower SNR readings than those from the EBSPro Signal Analyser SNR or a satellite receiver SNR. Presumably due to the quick pass the software does when scanning a frequency range. This was not a global issue for all SNR but it did occur on some.
Is it an option to get the streamreader software or whatever software that manages the scan to do a slower speed pass in the hope that it captures a more accurate SNR reading? Or get it to do a return scan for those frequencies found and logged in a table and sit on them for several seconds to get the SNR?
Do a few limited freq range test scans on just one particular transponder MB but with different 'Method /Steps' settings - ie: start off with 1 MHz then 2 MHz up to 4 or 6 MHz and see if the S/N figures alter. I usually get higher S/N figures from my Promax when it is just parked on a particular frequency.
Do a few test scans on just one particular transponder MB but with different 'Method /Steps' settings - ie: start off with 1 MHz then 2 MHz up to 4 or 6 MHz and see if the S/N figures alter. I usually get higher S/N figures from my Promax when it is just parked on a particular frequency.
Yes, I think that is the logical way forward re smaller step scans and compare the results.
For those with a slight inclination towards IT tinkering, the entire EBSPro database of all historic scan results for all satellites can be easily exported and opened with a spreadsheet application. The EBSPro database is in SQLite format which can be opened by free SQLite database viewers. This allows reading and exporting of the EBSPro database as a csv file or a text file, both of which can be opened by excel or any other spreadsheet application.
It saves a lot of copying/typing and removes the risk of manual error for anyone wishing to keep/transfer records of their scanning forays from EBSPro into a spreadsheet.
PrvtN00b
2.4 PF, 1.8 Raven Offset and 1.2 offset for DTV
Panama Central America
Any hope to see a blind scan solution for this USB tuner??
HD USB Satellite HD DVB-S/S2-Geniatech MyGica
Khartoum Sudan
SkyStar USB HD, Desktop computer, Windows 10, icore5
Khartoum Sudan
Hi
I managed to configure CrazyScan for my SkyStar USBHD.
It seems I failed as I have received error message "checkForDVBEx".
I guess this related to the HW driver.
Any one for advise PLEASE.
