LED TV light bleed?
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Hi Guys,
I have bought my first LED TV a 24 inch supermarket set. As I have only had LCD before I'm wondering if this newly purchased LED has a problem. I suspect it is a common issue, if it is an issue at all. I have attached a photo but I'm not sure if it will show accuratly the issue.
TIA
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
So what do you perceive the issue to be?
4wd
Getting the picture
5 W, 9-13-19-28 E
Difficult to find some display with zero bleed, but looking at that picture, IMO that's too much + it's placement in the top middle makes it an irritating distraction that can't be overlooked. I'd return it and demand a new one, & if possible check it in the shop before taking it home.
That's far too prominent.
I'm guilty of buying cheap Bush branded Tellies and have not come across one remotely as bad as what yours displays.
Return and exchange.
skomedal
This and that
thule
Did you have it calibrated and software upgraded at the purchase point ( read shop ) before delivery?
Regards
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
It was a Tesco internet order, our store doesn't sell TVs, Sure thing I will box it up for a replacement.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
After the horror reactions I think I will get it replaced.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Regards
Unfortunately supermarkets don't offer this bespoke service.
Hi Guys,
TIA
If you select the TJC channel from the epg it will be cured. Have faith.
Terryl
Custom built PC
Try turning the brightness down, the bleed your seeing is from a improperly aligned LED strip lighting bar, this LED bar has super bright LED's (24 or more) that light up the back of the screen, if the diffusion mask or LED strip is out of alignment you will see something like in your photo.
Nothing short of tasking it apart can be done except trying to turn down the brightness to see if it goes away, I would send it back calling it hidden shipping damage.
I had a strip from an LED back lit TV, I turned it on, I emediatly turned it off and went out and got my gas welding goggles, they are really really bright, it lit up my whole house.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
I have turned the brightness down but it had no affect, it changed the rest of the screen but not the rogue LED's.
It's going back because I don't fancy opening it up, I only took delivery yesterday so I will try to get it replaced.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
I wonder if I will have more success in saying damaged in transit or faulty item after all it is a manufacturing fault?
It's faulty. Period.
Terryl
Custom built PC
FUBAR..........
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Called their line for electrical items and it's booked for a replacement so hopefully the new one will be good. Thanks guys.
Suppliers rarely actually check these days but, as you've found, simply take your word for it.
Indeed, your faulty one will more than likely find its way back into the supply chain without actually being fixed. Argos once supplied me with what was clearly a faulty return item ...... the Manager's ears bled after that particular incident.
4wd
Getting the picture
5 W, 9-13-19-28 E
Last time I bought a lcd, I went to a shop with large numbers on display, looked for the best one (within my price range), found a 27" Samsung socalled gamimg monitor that had a -very- good backlight 'evenness', and demanded to buy it. The 'it' was the unit on display in the shelf, not taking the chance of getting some random one and once home seeing trouble. The staff refused, but I persisted and got it. It's excellent, using it for tv\pc \sat.
Buy lcd's like you'd buy a woman, take a look first, don't get them in a sealed mystery box and wrapped in plastic lol+++
