- Promax HD Ranger+ spectrum analyser.
- Derbyshire
Hot on the heels of the 800 Mhz band clearance and the fitting of filters t0 prevent LTE TV interference, the 700 Mhz clearance is kicking off shortly, starting in Scotland.
This may involve the fitting of a masthead or set back filter, even if you've already had one fitted to remedy 4G interference from the recent 800Mhz clearance. If you receive your signal from a transmitter which uses frequencies close to the 700 Mhz band, then there is potential for renewed interference.
Digital UK | 700MHz clearance
