New Toy - LENCO L-175 USB Turntable
Archive-8
Specification
Technical specifications for LENCO L-175 USB Turntable
OVERVIEW
Type Turntable
Colour Black
PERFORMANCE
Number of speakers 1
FEATURES
Playable CD formats No
Other features - Convert vinyl to digital formats
- Integrated switchable stereo pre-amplifier
CONNECTIVITY
Wireless No
Bluetooth No
NFC No
AirPlay No
USB USB 2.0 x 1
POWER
Power options USB
Standby power consumption 1 W
Normal power consumption 25 W
GENERAL
Box contents - Lenco L-175 Turntable
- Instruction manual
- Software CD
Dimensions 420 x 340 x 110 mm (H x W x D)
Boxed dimensions 450 x 380 x 160 mm (H x W x D)
Weight 5.1 kg
Boxed weight 7.2 kg
Manufacturer’s guarantee.
I should have it tomorrow.
Good luck with that - biggest issue with on-board USB-to-phono converters or straight-to-USB inputs to amps appears to be the onboard D/A converters themselves - some are good but most appear to be poorer than separate good outboard D/A converters from all I have read.
Let us know what it's like. I prefer to feed direct post-pre-amp output to my sound card. No idea if it's better but it seems more err... right?
Archive-8
I just want it as turntable, I have no intention of using the USB function.
If I want the record the record I use my teac cd-rw unit.
The biggest plus for me is the ability to swap the stock headshell with my Shure M44-7 headshell.
My acoustic solutions deck has died completely, so has my Duel deck (age killed it) my project deck is so fussy on the condition of the records I can't really play them and enjoy them, it just sounds so clinical!
So hopefully this deck, with the Shure M44-7 cartridge I should be able to listen and enjoy my records.
Shure M44-7 - now that's a real "flashback" image - I at least got to the M75 series in the 70's/80's. Bought a Project deck about 10 yrs ago - but have hardly ever used it:(
archive10
I manage to drop and damage my Denon DP-35F some 10 years ago. Argh!
My better half bought me a new Projekt deck as a replacement.
Despite many good intentions, I have not managed to even unpack it yet... (although it sits there in storage, quietly waiting...)
Archive-8
My project deck has never been 100% it has an Ortofon OM-5E cartridge it's very bass light but very detailed. All records sound like a cd to me on my setup. Plus the OM5E tracks so light it skips at the slightest imperfection.
It's the motors that pack up on me.
I replaced that Ortofon with a higher spec one that has a higher tracking weight - seemed Ok during the little that I used it.
As for the CD sound, might that not point to the amp&/or the speakers?
Archive-8
I am using it plugged into a project tube box s into my maverick d1 plus tube, upgraded the dacs to burr browns that is then plugged in to my quad elite pre-amp and quad elite mono blocks & B&W 683 S2's.
All other decks with the Shure Cartridge all sound amazing it's just the project that sounds "meh"
Chris
That Shure cartridge is not necessarily the best for a deck like a Project because the M44 range was essentially a budget range for use in low-end decks like some of the Garrard and BSR autochange decks with relative crude arm adjustment mechanisms. For something like a Project or better, a higher spec cartridge would normally be expected to be used - "horses for courses".
Looking into that Ortofon and the Shure a bit more, they are two very different beasts: the first is a lowish-end lightweight hifi cartridge with a low tracking weight (1.5-2.0gms) whilst the second is a "DJ" stylus that is heavier and (presumably) is of sturdier construction with a higher tracking force range (1.0-3.0gms) and is claimed to have a very high "skip resistance"- and so no wonder that the Shure does not baulk so much at imperfections on the records!
Edited: Also, the Shure has around twice the o/p voltage of the Ortofon, - so it's almost certainly going to sound "louder" than the latter. Can you adjust the preamp gain to compensate for that?
Nevertheless, maybe that Ortofon is not the "right" cartridge for you - so maybe one of the Stanton range might be a more suitable modern cartridge for you.
However, might the real problem be your records - are they really flat and "clean"?
BTW: feeding your pretty high end pre-amp, amp & speakers with a cartridge like the Shure or the Stanton is a bit like feeding 2* petrol to a Ferrari engine which is designed to run on 5* fuel :-lol
Archive-8
The new deck turned up today :) only slight issue I had was the shape of the headshell.
I had to swap the cartridge for my Shure, only had chance to try a record and it works, I will give it a good test tomorrow.
@jeallen01 yes the tube box s & the quad pre-amp both have adjustments. You maybe on to something about the being to "clean" I will try a few without cleaning them first.
Ortofon cartridges have always been a bit "fly" the one I had in a B&O BeoCentre that thing would jump when a car went past the house, sadly this OM5E does, for me it's not "plug n play"
The lenco headshell and cartridge:-
The Shure cartridge before I swapped the plastic headshell
I will try and get some better photos tomorrow.
Chris
A thought - what do you use to support the t/t? Hope it solidly mounted and maybe with some sort of compliant material in between to absorb any external shocks/vibration? (I have almost always mounted mine on a "dead" material shelf firmly bolted to the wall as that sorted any external influences - even when I was having a VERY loud party - and mistracking rarely happened).
I also assume/hope you have used a decent stylus balance and alignment gauge as that can make big difference. BTW, wrt the Project deck, the standard balance weight might have been too light to get a heavy cartridge to balance correctly (the top end of the tracking weight range is usually the best approach to avoid mistracking and "jumping"), but there are heavier balance weights available - my Project t/t is fitted with one).
Archive-8
Chris
I have had similar ideas about a dedicated shelf for the turntable, at the moment it's on a solid bit of wood on top the stack. It's not ideal but is functional.
My acoustic solutions deck tracked heavy, fitted with the At-96 cartridge and never "jumped" I had enjoyable music.
Most of my records have had a hard life and a few I can no longer play, so all I need now is a deck that is "plug n play" that's the hope anyway.
I do have a set of digital stylus scales I set it up with that.
The tracking weight was one of the things that helped my decision. I wanted something fatter and heavier in the groove, and a "fatter" bass.
Chris
I would never mount a deck on top of a stack of other stuff - IMHO, that's a recipe for "disaster", especially when you are talking about a high spec t/t & cartridge because that sort of combo (especially if the t/t has no internal suspension like most Project decks!) is likely to be very sensitive to both internally and externally generated shocks and vibrations - which can cause mistracking and "jumping"!
In the current circumstances, it's no wonder that you need to use high tracking weights!
Edited: Had a look at the Lenco deck and it looks like another one with no internal suspension, so maybe you will have the same problems as with the Project? Therefore I suggest that you "fix" the basic issue, which is the way the t/t is supported!
Archive-8
That will have to be on my to do list.:)
I'd do it PDQ so that you can consider sending the Lenco back and get your money back if the Project then does the "business"
Archive-8
Nice thought, but me and the project deck have come to an end, it's caused me so much stress hassle and money and I have never been happy with it. I wonder what made me buy the thing in the first place.
Yes I know I need to sort the shelf for it, my new 4K panel is still in the box, I need to sort and move a few things about so I can get some new cables installed, for other projects I have.
Thanks for your help :-)
