Parts Challenge ..
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
I have 2x T4900CT win95 laptops ..
Neither have a functional floppy drive..
both floppies could be repaired IF..
I could find a source for drive belts.
Approx 70mm diameter (not critical)
0.5mm square section belts ( cross sectional dimensions are critical due to clearances - but could be round section maybe)
many belt kits out there but usually start at 1mm cross section (too thick)
problem is ..the neoprene rubber has perished ...become plasticised ..and fused to the pulleys.
Obviously these were never intended to be repaired..
If you find anything suitable ..let me know.
rgds
VS
Archive7
I bought few drive belts for a tape cassette deck.
Not sure if this is what you want, but try this shop (USA)
www.studiosoundelectronics.com
Didn't find 0.5mm belts when I checked now
The store will reopen on 28th July. You can consult with them perhaps they can help you
Good luck
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
guess I'll wait for the 28th July ..and send an email..
I'm finding it hard to believe that non of the UK parts suppliers is able to help.
but that is how it's looking atm
From 1994, before the Satellite Pro series
There's also the awesome power and speed of the Intel Pentium 75 MHz, 3.3 volt processor to accelerate your every move, and an 8 MB RAM that's expandable up to 40 MB*. This combination makes the T4900CT the most capable notebook on the market. And it's underlined by the T4900CT's 770 MB (810 mill. bytes) hard disk and 16 KB on-chip cache.
Terryl
Custom built PC
Some peep's I knew used old bike tire inner-tubes, the ones used for racing worked wonders for small drive belts, (on old tape drives) the smaller the tire the smaller the cross section, a very sharp razor blade can slice some really nice cross sections, (and your fingers) but they may be too thick for your needs.
pgh13
Midlands UK
Try searching for chart recorder drive belts. There may be something there that suits
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Indeed ..they were pretty awesome in their day ..and still fuctional but for the floppies and sadly the battery packs ..
which are 12v and use 10x 1.2v NiMH ..so no balanced charging required ..
I will also attempt battery pack rebuilds if I can fix the floppies..
These are the battery types I believe..
BATTERY NI-MH +TAGS 7/5AF 3.7AH 1.2V - Rechargeable - Batteries | eBay
but no way am I paying stoopid prices for 'em..
2cvbloke
Near Pontop Pike, Co. Durham
Expensive for some NiMH 17670 sized cells (narrower than an 18650, and slightly longer, but also 1.2v), a quick google reveals many alternative sources for such batteries... :)
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
upload_2017-7-29_19-22-0.jpeg upload_2017-7-29_19-24-37.jpeg And...........
At the back of the shed I found this in a small protective case. It has a Win95 sticker underneath.upload_2017-7-29_19-24-37.jpeg
Ill run her up on Monday, see what it does, or doesn't.
Z-NOTE GT NOTEBOOK: OVERVIEW
