EPG Update Transponder
devonbrown
4 systems. In Scotland Freesat with Humax Foxsat recorder. In Algarve 1.5 fixed Inv Quad LNB with 3 Pace 2600C1 and 1 Amstrad HD DRX780UK also 80cm dish with Inverto 0.2db monoblock LNB (19.2E/26E) feeding Technomate 5000CI+ usb.
Scotlandl and Algarve
Does anyone know what the 28.2 update transponder is? After a 4 month absence the EPG on my TM-F3/5 is not updating when I tune in to EPG. Is the 7 day EPG update info now on a different transponder? TIA
devonbrown
For some unknown reason the EPG is updating normally now. Perhaps there was transmission glitch
John Pykett
Persona non grata
Dish setup: 80cm Motorized Dish, TM-5402 HD M3. This setup goes from 1w to 28.2e
My computer setup: AMD Athlon II X4 645 3.10 GHz processor and 8GB of ram. Graphics Card is NVIDIA GTX 750 Ti. OS: Windows 10 64 Bit
Hucknall, United Kingdom
well for some reason mine has not been updating on my tm 5402
John Pykett
Persona non grata
Without some addons all you will get is now & next.
actually thats not true cause the epg 7 day does work without addons cause i tried it before and i got more data
You get that on the German stations on 19E. If 28E is now carrying enhanced epg past now & next that must be a relatively recent change
John Pykett
Persona non grata
i think it might be cause i used the epg data channel to load the data in memory
The Sky & Freesat epg data streams are not readable by generic receivers - thye use none standard data formats
John Pykett
Persona non grata
you sure cause it worked for me strange?
trigger
Puerto del Carmen, Lanzarote
30W, 27.5W, 7W, 0.1W
4.8E, 9E, 13E, 19E, 23.5E, 26E, 28E
Technomate 5402HD super
Bein Sports on 25.5E
FTE Mini S2T HD Analyser
Horizon HD S2 sat meter
Lanzarote, Canary Islands
John Pykett
Persona non grata
Do you have some non-standard firmware in the machine, as -alluded to by Lazarus ?
Are you pointong to the right satellite when you are trying the epg ?
John Pykett
Persona non grata
yes its on the right satellite cause it worked before. oh well i hardly use epg anyway
davemurgtroyd
Oxford
Oxford
The yoof of today have no staying power. They give up too easily:)
