CTAGGY
- Jun 19, 2017
- Age
- 63
- have not got one yet
- Peak District
Your dish is a Mk1, they're the only ones with the very thin LNB arm, if you buy the bracket above and a Mk4 LNB, should be a straight swap out, have done many over the years.Does the difference between the oval feed and the circular feed mean that the above adaptor will not work ? Plus will the adaptor change the existing setting ? Are there any packages adaptor and LNB that come as one and would work ?
Thanks Tag
ps is it possible to tell what my my dish is from the above adaptor ?
