My new Scalar ring and C-band LNB
shawl_who
SES7, Yahsat 1A, Yamal 54.9e, express am33 @103e, eutelsat 36b
New Delhi, India
This is the special CB1 lnb for C-band, for Ku band dishes.
Package included:
1. C band lnb
2. Scalar ring ( robust quality)
3. clamp
4. screws
That is for an offset dish, not necessarily Ku band type.
...it may also be anti-interference.Tell me/us if it is as I suppose!?
Terryl
Custom built PC
I hope the dish is bigger then 1 meter, otherwise you may have problems with signal quality.
I played around with trying for "C" band on a 1 meter dish, junked the idea after too much hair loss, and several bad Sun burns.
shawl_who
New Delhi, India
yes, clamp is specifically designed to fit on an offset arm, and is bigger than the normal Ku lnb clamps.
Its a normal scalar ring, reduces noise signals, thereby enhancing the actual signals.
Getting a flat signal increase of 6% using the scalar.
I ll fiddle around on a 1.2 m dish.
Sun burns... well, wont get them, as I usually track in the evenings/nights. :D
shawl_who
New Delhi, India
Archive-8
You can get some stuff on a 1.2 dish, I used to have c-band on the side of my 1.25 Gibertini.
40°E/20°E are a very easy catch.
Just watch the position of the plate.
Good luck and happy hunting :)
shawl_who
New Delhi, India
Thank you.
Already tried my hands on Intelsat 20 @68e.
Unfortunately, cant catch 40e/20e in this part of d world. :(
Archive-8
Not in India , unless there is a New, New Delhi somewhere.
I normally view the forum with my iPhone in portrait view, so I didn't see the original posters location.
I need to turn the phone into landscape mode, then I can see the location.
