Recording Several Channels from Same Transponder
Archive7
The Octagon SF4008 does support CI+ cam with the HD Freaks image. I use it for her indoors to watch Fransat with a CI+ module and Fransat card.
Did you get a user manual inside the box and does it mention support for CI+?
Nozahic
Vu + , fransat
Good afternoon
I would like your help, I am based in U.K. And I am French, I bought a Fransat box with card. The box is not good because you need external memory for record.
I bought a old vu+ duo box, and i want to put my card in for have a better recording system.
After 1 week of advice from people , I mange to settle my box on satellite 5w from Fransat, but I only have few Chanel I can watch like Vosge TV, I can't access to TF1 or France 2, ect. When I put my card in, nothing
I would like if someone can let me know what I need to do for have my vu+ and fransat card connect together
I am new on this system, I will need a lot of detail, other where I can send my box for be settle properly because I don't mind to pay for this service
Regards
Archive7
Most receivers require an external memory (flash stick like Sandisk or HDD with or without external adapter).
If you need an internal memory then the cost of the receiver can be more expensive and you have limited size.
If I misunderstood what you mean, then please correct me.
Using VU+ with a TNT card can be quite complicated but if you have the patience and knowledge you will get there in the end.
Good luck and welcome to our forum
Nozahic
Vu + , fransat
Thank you for your reply
I have a external memory ( Sandisk ) but the quality of recording is not good
It is for that I would like to put my Fransat HD card in my Duo+ box for have a better box but I am new in this system and I would like to find someone who can help me to settle this system
Regards
Archive7
A flash memory is not the best option to use. I know from my experience.
Try using an external HDD with a power adapter and if you still find the recordings not good enough, then move to VU+ option.
Nozahic
Vu + , fransat
Thank for your reply, I am new on that, have you got any recommendations for a good external HDD with power adapter. Maybe one I can have on amazon . Because I don't want to order something who don't work.
About the vu+ box, how difficult to connect them to Fransat ?
If your first recommendation work, I will sell again my vu+ duo box
Thank you for your help
Archive7
I have used Western Digital My Book with many sizes and I have excellent recordings.
They have USB 3.0 support.
I usually order from Amazon Germany but you can try Amazon UK if it is more convenient for you or even Amazon France.
There might be slight differences in price so check on all websites and see what is best for you.
My Book Desktop 4 TB schwarz: Amazon.de: Computer & Zubehör
But you can order smaller size than 4TB but I am always short of storage.
4wd
Getting the picture
5 W, 9-13-19-28 E
Bonjour, avec beaucoup de connaissances sur enigma (vu+ et similaires) certains disent qu'ils ont reussi.
(some with lots of experience in enigma etc have managed).
But would definitely not recommend it if you are new to enigma\vu+ etc.
About the Fransat box, maybe just get a 2.5 " hd external, the box will (should :O) power it without external power, check the user manual.
Am using a simple Philips box for TNTsat (astra 19) here, and it works fine with a 1TB 2.5" external, power from the box \ usb cable.
Archive7
Hang on to your VU+ box. It will give a lot of pleasure learning about images and plugins.
And the most important feature for me is that I can move any recording to my PC for further manipulation.
I bet you can't do this with your Fransat box because most probably it encrypts the recordings which means if your box dies, then your recordings die with it. (unless you buy a similar box in the future, maybe)
Nozahic
Vu + , fransat
Hi all
Thank for your help
Because I am not good enough on this system, I will try a better external HDD.
I find that on amazon uk, someone can say if it will be good
https://www.amazon.co.uk/Seagate-Ex...05147098&sr=1-1&keywords=external+hard+drives
HB13
I have 3 vu+ duo because I used them few year ago when I was living in Spain for have multiple room because Sky UK cut my multiple room but the box was all settle from the seller and I never understand the way the was working
I will try to sell them for pay my external HDD
Archive7
HB13
We have a classified section you can try selling them there. Read the rules first.
Private Classified Adverts - No Traders
Nozahic
Vu + , fransat
HB13
Can you look the external HDD i find on amazon uk and let me know if that will be good
Of course I will try to sell here my 3 box
Regards
Archive7
HB13
Regards
I can't give an opinion on a product that I haven't used. Sorry
Seagate isn't on my favorite list
Nozahic
Vu + , fransat
HB13
Thank for your reply, I will order this one with 4TB , it had everything I need ?
Sorry but I do no nothing about that and prefer ask references
Regards
Archive7
I used only 1TB but if you want 4TB check if your box can support this size first.
You can always return the product to Amazon I think they give two weeks window to return an item if a customer is not satisfied.
BTW Maxtor is now part of Seagate.
Good luck.
Nozahic
Vu + , fransat
Ok I will check what is it my size at the moment
Thank for all your help
Regards
TJExcalibur
Out of this world.
Southern England
No manual as such and found out about CI+ from a web search.
