Tururu
Assembled with recycled parts
Recycled as the owner.
- North of Madrid (28703 Spain) -3Km of IKEA (40.545847, -3.612012).:-)
@stephan94
4:2:2 tachado de la lista/crossed out the list. ok.
Problem.
When doing the search in 23'5ºE tune to 19'2ºE channels, it is a problem for some, that is why the verification that realizes and to see the bandwidth (automatic control of frequency), therefore sometimes it is necessary to put the data to hand and seek.
The 3Mhz of difference can be solved/taken into account, but the SR+1711, I ate it with potatoes.
I search TP ................................................... Meeting.
11680 V 1023 2/3 DVB-S2 / 8PSK ............ 11683 V 2734 5/6 DVB-S / MPEG-4 Kitchen TV
When using the blind search on very close satellites, you will normally find channels that do not belong to the satellite.
It would be nice to be able to limit the search by frequency ranges, polarity, also filter the relationship of TP found with nearby satellites, 1º, 2º, so it is necessary the file satellites.xml where is the relation of TP's.
Some of us have this very personalized satellites.xml file because of this problem.
Problema.
Al hacer la busqueda en 23'5ºE sintonice canales de 19'2ºE, es un problema para algunos, por eso la verificacion que realize y ver el ancho de banda (control automatico de frecuencia), por eso algunas veces es necesario poner los datos a mano y buscar.
Los 3Mhz de diferencia se puede solucionar, pero el SR+1711, se lo comio con patatas.
Busco......................................................................Encuentro.
11680 V 1023 2/3 DVB-S2 / 8PSK ............. 11683 V 2734 5/6 DVB-S / MPEG-4 Kitchen TV
Al usar la busqueda ciega en satelites muy proximos, normalmente encontraras canales que no pertenecen al satelite.
Seria bueno poder limitar la busqueda por margenes de frecuencia, de polaridad, tambien filtar la relacion de TP que encuentre con satelites proximos, 1º, 2º, por eso es necesario el fichero satellites.xml donde esta la relacion de TP's.
Algunos tenemos este fichero satellites.xml muy personalizados por este problema.
PD: Por pedir que no quede.
Problem.
Problema.
