OCTAGON SX88 H.265 HEVC HD
stephan94
Bavaria
To record then, could be enough.....
On the other hand records are currently without subtitle.
What programs have subtitles on 40 ° East?
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
3915 L
DVB-S2/8PSK
MPEG-4
T2-MI 14990 3/4
Did You check m6 and tf1?
Thank
stephan94
Bavaria
M6 and TF1 have not continually subtitles, It's just that for some programs (rare)
Pierangelo
Italy
I have other 3 boxes with french TV, et Les Subs sont plus que communes par tout!
Merci
stephan94
Bavaria
Yes but TF1 is sent not subtitle in the Multistreams
here you can see an example. (stream with a TBS 6983)
the sub titles is announced, but in reality there is no subtitle.
Pierangelo
Italy
On 40 east, sub are available sometimes on public tvs.
Smartdvb Can get them.
Pierangelo
Italy
Sorry, but I keep my idea. Octagon 4008, E2, can handle sub. Try
stephan94
Bavaria
No problem.
The SX88 can handle subtitles as 4008 but only when there are subtitles.
The only difference between the SX88 and 4008: the SX88 does not record subtitles.
a exemple with the record from 4008 TF1: no subtitle as the SX884008 untertitel TF1 MIS.jpg
Pierangelo
Italy
Series has always Subs.
I am not convinced... My tests are for "not working properly".
But I thank You for your commitment.
Ciao
Pierangelo
Italy
Please, I ask for more powervu keys on 40 west and generally south american TVs.
thanks
stephan94
Bavaria
Here we do not talk about encryption!
You have a U2C Denys,
why do not you ask all your questions U2C Denys forum?
SimonE
Gloucestershire, UK
stephan94,
I wonder if the SX88 has a hidden menu for setting up the HDMI video? Compared to all other inputs to my TV the SX88 produces dark pictures.
stephan94
Bavaria
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
Will there be a database editor for this receiver? Mine arrived yesterday and I would like to add in some missing satellites. I use a traditional motor and prefer my satellites in order. Belintersat1 is missing as well as ABS 3a and I would like to add in Bulgariasat when it switched on.
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
Octagon says they are working on an editor. All you can do for now is manually add satellites using the receiver.
Diseqc 1.2 motor controls are hard coded to the satellite number. So if you select the third satellite in the list, the receiver automatically assigns the diseqc 1.2 number to 3. This is not good.
I changed my list manually & used some of the C band satellites such as Azerspace 1 then I relocated the other satellites
Set up in DiSEqC 1.3 USALS
My SX88 Channel List
53E Express AM6
52.5E Al Yah 1
52E TürkmenÄlem
51.5E Belintersat 1 (previously AzerSpace C band)
50E Turksat 4B
46E AzerSpace 1
45E Intelsat 904
42E Turksat 3A
39E Hellas Sat 2
36E Eutelsat 36B
33E Eutelsat 33C
28.2E Astra-2
26E Badr-4
23.5E Astra 3
21.6E Eutelsat 21
19.2 E Astra-1
16 E Eutelsat 16
13 E Hotbird
10 E Eutelsat 10
9 E Eutelsat 9
7E Eutelsat 7
4.9E Astra 4A
3.1E Eutelsat 3
0.8 W Thor 5/6/7
1.0W Intelsat 10-02
3 W ABS 3A (previously 1 west C band
4 W Amos 3,7
5 W Eutelsat 5W A
7.3 W Eutelsat 7W A
8 W Eutelsat 8W A
11W Express AM44
12.5 W Eutelsat 12W A
14W Express AM8
15 W Telstar 12
18 W Intelsat 901
20 W NSS-7
22 W SES-4
24.5W Intelsat 905
27.5W Intelsat 907
30 W Hispasat
Other satellites at this end of the arc can be added as & when they become active.
If an editor does not materialise then I will have to use EW5A C band so that I can fit in Bulgariasat @ 1.9 east & shuffle the satellites around 3 east to 5 west.
53E Express AM6
52.5E Al Yah 1
52E TürkmenÄlem
50E Turksat 4B
46E AzerSpace 1
45E Intelsat 904
42E Turksat 3A
39E Hellas Sat 2
36E Eutelsat 36B
33E Eutelsat 33C
28.2E Astra-2
26E Badr-4
23.5E Astra 3
21.6E Eutelsat 21
19.2 E Astra-1
16 E Eutelsat 16
13 E Hotbird
10 E Eutelsat 10
9 E Eutelsat 9
7E Eutelsat 7
4.9E Astra 4A
3.1E Eutelsat 3
0.8 W Thor 5/6/7
1.0W Intelsat 10-02
4 W Amos 3,7
5 W Eutelsat 5W A
7.3 W Eutelsat 7W A
8 W Eutelsat 8W A
11W Express AM44
14W Express AM8
15 W Telstar 12
18 W Intelsat 901
20 W NSS-7
22 W SES-4
24.5W Intelsat 905
27.5W Intelsat 907
30 W Hispasat
If an editor does not materialise then I will have to use EW5A C band so that I can fit in Berlintersat @ 1.9 east & shuffle the satellites around 3 east to 5 west.
One of the firmware updates recently added a very updated satellite list, including all C, Ku and Ka satellites.
stephan94
Bavaria
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
53E Express AM6
52.5E Al Yah 1
52E TürkmenÄlem
50E Turksat 4B
46E AzerSpace 1
45E Intelsat 904
42E Turksat 3A
39E Hellas Sat 2
36E Eutelsat 36B
33E Eutelsat 33C
28.2E Astra-2
26E Badr-4
23.5E Astra 3
21.6E Eutelsat 21
19.2 E Astra-1
16 E Eutelsat 16
13 E Hotbird
10 E Eutelsat 10
9 E Eutelsat 9
7E Eutelsat 7
4.9E Astra 4A
3.1E Eutelsat 3
0.8 W Thor 5/6/7
1.0W Intelsat 10-02
4 W Amos 3,7
5 W Eutelsat 5W A
7.3 W Eutelsat 7W A
8 W Eutelsat 8W A
11W Express AM44
14W Express AM8
15 W Telstar 12
18 W Intelsat 901
20 W NSS-7
22 W SES-4
24.5W Intelsat 905
27.5W Intelsat 907
30 W Hispasat
Thanks for the advice. The satellite position numbers being positioner numbers could be good if we could allocate the position ourselves ....which I had on the X2 premium receiver. So far, I miss the Pos button from the Technomate for fine tuning and the very good spectrum analyser from my Dr HD D15 which was far superior to the Technomate analyser. Sadly the IR receiver started malfunctioning making controlling the receiver impossible.
I am getting used to working with the Octagons logic and hope this will be my main controlling and blind scanning receiver using my other Octagon for UHD and DVBS2X.
Laser
It would be so useful if these updates were available over the internet when you switch on... ie the receiver says updates are available.
So easy to miss one of these if you away from the PC for a while as I was on holiday
