- See Signature
- Somewhere in England (possibly?)!
That's the question because, having now installed the "new" TD110 on a new Superior Darkmotor (metal gears but it might well be a clone version
), I think I have got the alignment pretty much correct as it does cover the arc of 52.5E to 30W with reasonable results.
However, using the TM5403 M3, I can only set the angular position to 1 decimal place - and yesterday I found that I could not really distinguish between 52E (TurkmenAlem/MonacoSat) and 52.5 (Al Yah 1 /Yahsat 1A); in fact getting stronger channels on both sats at the same angular setting (= probably "somewhere" between 52 & 52.5)
OTOH, using the Free Sat V7 “Fag packet” on which you can set the longitude to 2 decimal places, I think (it was a few days ago) I could set up both sats at different positions.
I realise that the dish beam width (as related to its size) is a significant factor but this made me ponder on what "degree of discrimination" (as opposed to "degree of longitude") you can reasonable expect from a DiSEqC motor - and is this likely to be affected by the sat positions in question being right at the extreme ends of the arc available at the dish site (which I suspect it might be because the sat-dish path distances are somewhat longer there than when the sat is directly "overhead" of the dish)?
I suppose there is a subsidiary question as well: to what level of angular degree accuracy can you really expect to set the dish mount on the mounting pole (it seems to me that to get that down to even around 1 deg is very difficult and to get it any "closer" is verging on the "impossible" unless you have some means of making micro-adjustments)?
