OCTAGON SX88 H.265 HEVC HD
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
Hello
to store all positions in Disecq 1. 2 must be put every time
a cross on each satellite that stores.
since version 1. 04. 27 it works perfectly
ps:for now it is best not to use DreamBoxEdit, this causes errors in the frequencies.
Unfortunately this did not work for me. I have reverted back to software that worked. Would it be possible to post an EU satellite database that works with you to see if this is the problem? I would be able to set it as the default database.
stephan94
Bavaria
Whenever you find a satellite must do a search on one frequency and
only after put a cross in front of the satellite record with Disecq 1. 2 position.
stephan94
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
only after put a cross in front of the satellite record with Disecq 1. 2 position. I suspect it has been corrupted.
stephan94
The new software imported my existing satellite and channel database but not stored position numbers unfortunately.
stephan94
Bavaria
IT must not import the database from the old SW
Unfortunately must be a werkreset and start all over from the beginning.
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
The new software seems to have changed the way Diseqc 1.2 positions are stored. Each diseqc 1.2 position has to be stored as shown in the screencap. Position 1 will be stored first, Position 2 will be stored second. Position 3 will be stored third...ETC.
It does not matter what number the satellite is in the satellite list. the first diseqc 1.2 position stored will be Diseqc position 1. It is important to save each diseqc position as shown in the screencap. (See link. Cannot attach.)
If you change a satellite's motor control to None after assigning a diseqc 1.2 position to that satellite, then whatever position number that satellite had will be deleted and reused by the receiver. Setting the diseqc 1.2 of a satellite to off after assigning a position to that satellite may change all or part of your diseqc 1.2 numbering!
I have 24 diseqc 1.2 positions entered and tracking correctly using the 10429 software. It is a great headache to set up. I hope it is fixed so we can use or assign the diseqc 1.2 numbers that we need instead of what the receiver wants us to have.
MEGA
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
MEGA
Thanks for your input. I do not have a problem with rebuilding my channel database. The difficulty I am having is as follows:
I install the latest software.
I set to factory default. The screens are now in German but I still have my own satellite and channel database.
I reboot the receiver to see if the default channel database will appear including pulling the plug in case that works but, on reboot, my channel list is still there.
My question is how can I get to the default database?
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
Ok, finally cracked it. I had to go to a previous software which had the option of removing the default database and then reinstalled the latest firmware and factory defaulted. I was taken into a new setup screen and I now have a world wide database of channels. Choosing the satellite with a tick and changing the motor to a 1.2 one now allows me to allocate to position 01. Repeating this process with the next satellite saves to position 02 etc.
Now starting on the long road to rebuilding my channel database!
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
Looks like the SX88 added a couple more entries in the satellites.xml file. I do not remember seeing the mts or plsN entries before this last update.
<sat name="95.0W Galaxy 3C C Band" flags="0" position="-951">
<transponder frequency="3871000" symbol_rate="15000000" polarization="0" fec_inner="0" system="0" modulation="0" mts="0" plsN="0"/>
<transponder frequency="4001000" symbol_rate="30000000" polarization="0" fec_inner="0" system="0" modulation="0" mts="0" plsN="0"/>
<transponder frequency="4080000" symbol_rate="31250000" polarization="0" fec_inner="0" system="0" modulation="0" mts="0" plsN="0"/>
stephan94
Bavaria
New SW for the SX88
OCTAGON SX88 H.265 HEVC HD | Octagon-Germany.eu
--> Firmware Version V10431 - 14/11/2017
- SX88 H.265 HEVC HD
- E2 Settings Database Support verbessert:
- Gleiche Sender vom anderen Provider (Anbieter)
- Radio Gruppen E2 db verbessert.
- StartWizard (Installationssstart) verbessert.
- Media Player verbessert.
- Stalker Aufnahme Funktion eingebaut
- Stalker Vod Funktion verbessert
- Update CA
- Sprachen czech & polnisch update
- DVB Untertitel Aufnahme Funktion eingebaut
- NC+ und Cyfra FastScan Funktion eingebaut
- Voll BACKUP & Wiederherstellung Funktion erweitert:
- Menü - Installation - Backup & Wiederherstellung: OK Taste
- Speichere auf USB: OK Taste
- Wählen Sie mit ROTER und Starten sie mit GRÜNER Taste aus folgenden optionen:
- DVB Channel list, System settings, Stalker, IPTV, WebTv
- Lade vom USB: OK Taste
- Wähle Datei und wähle optionen wie bsp.:
--> Default PIN: 0000
--> Master PIN: 0088
--> WebIF (Web Interface): IP adresse wie Bsp. 192.168... im Browser Eingeben
--> FTP Zugang: Login: Root, Passwort nicht notwendig ! PW: sky1122
be careful
With this new SW recording function is no longer available
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
What do you mean? temporally?
""With this new SW recording function is no longer available
Danke!
Pierangelo
- DVB Untertitel Aufnahme Funktion eingebaut?
I am sticking with SW version 1.04.18 every thing works just fine in USALS DiSEqC 1.3
With my channel list compiled manually 53 east to 30 west in sequence.
Pierangelo
Italy
Please, remember them to keep recording function and to improve it:
- record both audio pid if dual audio;
- record Subs on teletext....
....... complete TS.....
thanks
stephan94
Bavaria
Pierangelo
Maybe it's better with Denys?
You have both Receiver, you can compare.
Marschall54
Sattelite receiver golden interstart germany
On the new SW version for SX88 ... can subtitles be made on French channels ?
Subtitling (just like sound) goes only to FRANCE 3.
These two problems (sound and subtitling) are the main problems missing at sx88 ... on some German and French forums, the same topics are also discussed.
There is always an example of another receiver that has both sound and translation, meaningless for SX88 owners ...
It also repeats itself infinitely, as some rights have to be paid for the sound to be implemented on French TV channels.
For the moment, the two main shortcomings are expected to be implemented ...
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
A feature I found accidently in the 1.2 positioner menu: highlight the transponder and press enter. This will change the transponder to the one which was tuned to when you entered the menu. It makes fine tuning of the satellite position just that little quicker.
Any more hints, anyone?☺️
Pierangelo
Italy
Pierangelo
Sincerely, apart some different color in menus, they are twins.
ciao
stephan94
Bavaria
Today I mounted my KaKu LNB, and tried.
The SX88 leaves a good impression
Already one has to say:
with Blindscan are only 3 frequencies 21545; 21571 and 21576 the others have a too small SR.
Otherwise with input he has two frequencies that can not be implemented in spite of signal not in program 21542 (Eden TV) and 21564 (Burkina Info), why, no idea. Otherwise he can quite well distinguish both very close program on 21538 and 21539.
Laser
Do you get good reception on 7east in Ka Stephan?
stephan94
Bavaria
From my location (Nord Bavaria) it is a bit more difficult with the 7 ° East
the frequency 21567H 1010 with QTV Gambia is just under the link margin, so unfortunately not to get.
For the other frequency and program, I easily get the channels, just TV2 on 21565 picture is not perfect because just short of link margin7 Ka-vert.jpg 21565 7 ost-tile.jpg .
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
