BulgariaSat-1 @ 1.9E
@s-band,my dish is 150cm too.I've adjusted my antenna well,but it's possible that if the signal is strong on a satellite, it will affect the nearby one and appear on a secondary lobe.Of course that those with larger antennas can avoid this situation. It is their turn to check the situation when satellites are too close...
pontiend
Contibruter
south yorkshire
This has just turned up here.It dose not seem to be from elsewhere.
TBS6983 100cm Dish.
Looks more promising just scanning 11700 to 12500 V & H
pontiend
Contibruter
south yorkshire
Two more Have appeared.
Edited TPs added
12300 H 27496 8PSK 2/3
12455 H 27496 8PSK 2/3
Just found them as well:-
12303 H 27500 2/3 S2 8PSK = 90% signal Quality
12380 H 30000 2/3 S2 8PSK =90% signal Quality
12456 H 27500 2/3 S2 8PSK = 90% signal Quality
added more data re video type & fec
12302 H,27500,2/3,Dvb-S2/8PSK,CCM-Data,
12380 H,30000,2/3,Dvb-S2/8PSK,CCM-Data,
12455 H,27500,2/3,Dvb-S2/8PSK,CCM-Data.
Modulation & FEC changes this afternoon:-
12303 H 27500 3/4 DVB-S QPSK
12380 H 30000 7/8 DVB-S QPSK
12456 H 27500 7/8 DVB-S QPSK
Laser
Maybe a testcard soon??
Yes let us hope so it has been a long wait this satellite has been here since July 3rd o_O
Indeed @william-1,new parameters for all transp.
SatSearcher
West Yorkshire
Does anybody get anything around 12150H or 12230H? I see 2 much weaker 'bumps' on crazyscan, i'm guessing these might be using the Balkan beam?
I think these bumps are just noise from satellite transponders switched-on, waiting for the uplink to be switched on as well.
Same goes for the whole range 12260...12500 V (6 transponders).
In my opinion I don't think 12150 H is active with all that can be seen as a signal?!?My antena is in the center of the spot,which has 52 dBW.
On the new Bulgarian Telecommunications Satellite Bulgariasat 1 are more technical tests that can spot even a television viewer. Bulsatcom operator tests the first satellite transponders.
Post a message in itself three transponders were active in the standard DVB-S with different parameters. Multiplexes so far no programs do not offer.
technical parameters:
• Bulgariasat 1 (1.9 ° E) 12.303 GHz freq, pol, SR 27500 H, FEC, 3/4, DVB-S/QPSK
• Bulgariasat 1 (1,9 ° E) freq 12.380 GHz, pol. H, SR 30000, FEC, 7/8, DVB-S/QPSK
• Bulgariasat 1 (1.9 ° E) freq 12.456 GHz, pol. H, SR 27500, FEC, 7/8, DVB-S/QPSK
They have changed parameter's a couple of time today Solly maybe they will start broadcasting next month more info here:-
MCelliotG
Thessaloniki, Greece
In my area:
12303 H 17.2db
12380H 16.8db
12456H 16.9db
these are excellent signals!
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Thanks.......different FEC on 12303 but all strong here in Alicante.
Enjoy your weekend. :)
hitech2016
Satellites
Morrocco
Mois aussi au morrocco
Black ultra inverto
1,40
50%
12304 H,27500,7/8-new Fec(7/8).
Increased the signal on all transponders.
