- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
Does anyone here have a service manual for the wkd28540 ?
I get E10 on front panel during a wash cycle
The sites I have looked at so far suggest a motor fault, and even replace carbon brushes, however this appears just as the wash is going through the spin cycle, the motor turns fine during the earlier parts of the wash.
If anything I would point the fault at a damper issue on the drum since the door no longer closes shut (watertight) after heavy load a few days ago.
I don't want to splash out on brushes and spend two hours or so to find the drum bearings, or damping system are screwed.
