eutelsat 5a 5w
I try to get signal over eutelsat 5w
I not get any signal
I see 11509h write wide beam multi stream no lock signal on 1.2m
any person got signal Greece or turkey or Cyprus ?
11509H appears to be on the superbeam not the widebeam. So Israel is well outside the coverage area. You will need a huge signal with the DVB-S2 8PSK FEC 8/9 - almost 11dBW just to get a stable signal. Plus you need a multistream capable receiver / computer card
adonis1
with 1.5m dish and Octagon SX88
deepbluesky
Terratec T-Stick+ (DAB+)
Stuttgart (48.79N/9.19E)
20km East of Iraklio/Crete a 1.80m does not get any frequency of the 5W Superbeam. This beam unfortunately is very sharp on its SE edge.
how about south turkey and cryprus reception ?
first thanks for the anser
it was also 11538h data signal before one year it also gone
Kypros_Pambou
TBS:6985,6925,5925usb
5 Pace&Arris IPTV Gateways
Greek Cyprus
Almost to lock the sat with very bad weather conditions. During the last 4 days here in Cyprus we have dust that comes from Syria .... ( 8 times more than usual )
I will try again when the phenomenon passes ...
Merry Christmas to everyone !!!!
I am not sure if 4K signals are considered as fringe reception? However, I have attached below a couple of 4K pics from 5.0W.
Frequency 12732V, SR 29950
ID NASA TV UHD
Lexzie
TBS 5925 USB-tuner
The Netherlands
What package do you have to get NASA TV? I have basic Fransat package.
Lexzie
TBS 5925 USB-tuner
The Netherlands
Then I'd like to know how.
The UHD channels are with provid 041980 and 0419A, and besides Viaccess encrypted with 4AF4 whatever that is.
The entitlements on my card are just for 041950.
You can get NASA UHD on 13E fta.
Lexzie
TBS 5925 USB-tuner
The Netherlands
There are three Fransat cards out there that work on the package, though only version 6 works without fault. Version 5 I think can be updated for NASA, version 4 should be replaced for a newer issue.
Lexzie
TBS 5925 USB-tuner
The Netherlands
I have version 6.
Guess my problem is using it in OScam?
Anonymous_1
I checked and I can confirm, it's active by default .
MCelliotG
Thessaloniki, Greece
This is what it is...
124512
Lexzie
TBS 5925 USB-tuner
The Netherlands
You are probably using a Fransat CAM.
If you have it working in OScam, please share it with me.
