C-Band Extended
satosk
Be independent and your TV screen will never be the same.
Slovakia - Heart of Europe
Well, at least somebody else who can receive this band. I know there had not been any info published so far on this web site... Sometimes there`s too much to do and not enough time.
I hope admin will not mind an external link just to show that this band is/has been actively monitored.
http://forum.dxtv.de/wbb/thread.php?threadid=20838
By the way is the model/manufacturer of the lnb used a secret?
Link coded
M
Anonymous_1
Yes @satosk , I know this thread, I am a full moderator for more than 10 years @ dxtv. de
The LNB is a Norsat , no secret ;)
Archived-1
Persona non grata
uk
Hi, what an interesting thread :), I've coded a link and had a little clean up.
Anonymous_1
30.5°E Today's scan
RHCP:
4737 R 2057 5/6, locked
Scan in LHCP, one frequency has left
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So ..I take it the extended C is only really used for data ??
Or have you found any exotic broadcast or feeds up there ?
rgds
VS
Anonymous_1
rgds
VS
Yes, this is it, only DATA found until now, FYI, the channel reported on Flysat @ 53°E doesn't exist or has left quickly (4280 R)...
Probably a fake: a promo in C band extended and also in 32APSK ... (I am not convinced).
4280 R must be a typo, 4200...4500 is not allocated to satellite.
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
Hello,
first test, but badly aligned LNB and please ignore my signal.
Position: 40.5°W SES-6
4544 R 20655 3/4 DVB-S2 8PSK, SES UHD package
4640 L 30000 3/5 DVB-S2 8PSK, NET
4581 L 30000 5/6 DVB-S2 8PSK, encr. package
Best Regards
qwer.
@ 40.5° West. 4516 RHC. SES Demo channel still lurking here but empty content at the moment.
@John , any help ?
4770 V 45000 5/6 8PSK, no LOCK
(not a very good signal ...)
Nothing to report i'm afraid, iv'e seen it here for a while now but can not get a lock on it . My Openbox S3 Mini HD rx captures it without any problem but that's as far as it goes.
Anonymous_1
OK, thanks John
If someone else can have a look , any contribution is welcome
Lexzie
TBS 5925 USB-tuner
The Netherlands
Which LNB is needed for extended C-band?
This is the one i use on my 2.2 PF Elite antenna. It's the most cost effective for me and it covers 95% of the domestic C-band coverage range.... ie: 3.6 - 4.8 GHz but is a compromise. It lacks the very bottom end ie: 3.400 - 3.600 GHz area, performance is pretty good over all it's frequency coverage range but not as good as a dedicated 3.4 - 4.2 GHz unit or a dedicated 4.5 - 4.8GHz unit. With these downsides in mind it really needs to be paired up with a dish size of at least 2.4m but ideally a larger size, 3mtr or so to get the most out of what's available to receive.... which ain't a fat lot - but things new do pop up every now and then. Other units are available from SMW etc but are far more expensive.
aceb
Prof Tuner 7301 /
Sussex
There is a possibility of a well known manufacturer of PLL C Band LNBs bringing out an extended version this year. In fact it already exists but has been produced under contract and they are unable to sell any similar product until this summer.
.. Very interesting, can you enlighten me a bit more on the brand or further info. PM me if you would rather at this stage.
Anonymous_1
40.5°W nothing really new
Cinelive ID instead of NET on 4641 L
4770 L SR is now 50000 16APSK 4/5 (not locked)
edit: tested with CM Feedhorn, not so bad ...
