Help Required SATLINK 6906. Lock light is always ON
massoudgharib
SATLINK WS-6906
IRAN
Sorry - as I said earlier, I wasn't sure if that was the correct file (I have a number of versions and I must do a better job of filing them
However, here is the bin file that I dumped from my own working late model 6906 a couple of weeks ago after loading transponders on quite a number of European satellites
Login - Dropbox
Regarding the pdf file (which is only 2 pages - 1 showing the early model button layout and 1 showing the late model button layout so that people can immediately identify which model they have), I think all you need to do in the post above is to click on the file icon and then you should be prompted to either Open or Save/Save As that file (works for me!) - but I have also uploaded it to the Dropbox folder and it is here
Login - Dropbox
But i read pdf file. 2nd page in pdf file is correct for my meter.
No, same as the original problem ..... "does not exist"
massoudgharib
SATLINK WS-6906
IRAN
i contacting to one of chinese company for this problem, if solved i will tell you
Update - I think I've found out the problems with Dropbox (and I'm not alone in having this issue), and so here are the links again:
The bin file that I created after I reset my 6906 to remove the "Lock" light, and then entered transponders on the strongest beams for the UK a number of European satellites
https://www.dropbox.com/s/1odzg9djn9ymjcx/2018-01-04%20Data%20Dump%203.bin?dl=0
Hopefully, that will allow a locked 6906 to be reset and to load that satellite and transponder database.
The pdf showing the front panels of the Early and Late versions of the 6906
Dropbox - WS6906 buttons - Early & Late models.pdf
massoudgharib
SATLINK WS-6906
IRAN
hoooooooooooooooora
working that.
many thank you
Well done both of you ...... perseverance paid off :cool:
Jaloga
Sathero 800 hd Astra 19.2E
Spain
Hello, thanks for the update, but I would like you to have a logo when you start the Satlink, and that will include the Spanish language, as it comes in this update, Update Satlink 6906 lenguage spanish
thank you very much,
the logo would be this
@Jaloga
Could be a useful idea but, sorry, I can't help with that! You will have to ask Satlink itself!
Jaloga
Spain
@Jaloga
I would like to know if the one you have put has made you, that's why I asked if you can implement the logo, anyway thanks
