Any one running dump 1090 willing to try an experiment?
Archive-8
Im very thankful of the ability to track other folks planes atm coz there is sod all happening up in Scotland atm!
Glasgow Intl. has been shut down completely for the last 2 hours & wont reopen until tomorrow
BA has cancelled almost all flights into Scotland from other UK airports, all Flybe's into & out of Scotland are grounded & Loganair has stopped flights from Glasgow Edinburgh & Dundee.
It’s dam annoying, as I was try to test another pi img. This time ascars.
That will have to wait now......
EmilK
1,2 m OF dish, TBS 6903 receiver, Inverto Premium Twin LNB
Austria
Feeding to Flightaware, plane plotter and Open Sky network
just tell me how
Receiver Profile
P.S.
@ Admin Thanks for looking over my post :-)
Archive-8
just tell me how
Receiver Profile
P.S.
Hi and welcome :D we are linking virtual radar server via the rebroadcast server option.
You can also use port forwarding to the ads-b receiver in my case it’s a raspberry pi 3 running Dump1090 plus 3 feeders to other sites, I am using a home brew aerial.
Added dump978 to the mix just haven’t been able to go ad by the bits I need to make the aerial for it.
I do have the second dongle plugged in ready to go.
What kit are you using?
EmilK
Austria
Im using the piaware image
This is pretty good coverage at the high flight levels for our 5 stations!
Even at 20000-29999ft its pretty damn good
EDIT - last 2 posts moved to the correct thread! :D
Archive-8
Had a message from @Confucian his set up has suffered a malfunction somewhere up the 45ft tower, so he will be down for about a week or so.
EmilK
Austria
For now feeding into Planefinder, Piaware, Open-Sky.
Using a piaware image but if you want my feed too you have to tell me how to add your server.....
Archive-8
You need to set up virtual radar server with a rebroadcast server enabled.
Then port forward the rebroadcast server port number (your choice) in your router.
Also you need to a ddns Address eg dyndns etc.
All the information needed to setup VirtualRadar is contained in this thread, if you get stuck ask, we will do our best to help you. (If we can)
Archive-8
My Pi is down for a while :eek:
I am going to have to re-flash/re-install everything.
Interesting - I dont get any of ttalex's planes fed over from Chris. I never saw any of Confucians either. Ive checked & Im using the right port
pontiend
Contibruter
south yorkshire
I normally get Confucians feed from Chris.When he is on line.
I assume that the continental ones are from ttalex also fed from Chris.
Archive-8
They are coming from my server. I have just rebooted the machine running vrs. It’s in base station format.
pontiend
Contibruter
south yorkshire
Yes I use Base station.
I asume that Liews planes are in the mix too,also fed from you.
