Advice Needed Bleeding paint!
pgh13
Midlands UK
SWMBO paints furniture - chalk paint etc. She's getting a bit narked that a factory applied finish that is 20 plus years old bleeds into the water based paint that is applied on top. Even into bog standard matt emulsion. I'd have thought it should be pretty inert after all this time. Any suggestions for a suitable sealer?
sonnetpete
wordpress.com
Normandy, France
Not sure about a sealer, but we've been using Farrow and Ball Estates emulsion. It's expensive but it's honestly the best paint I've ever used...
Try the sealers recommended when I did when I searched with this term in Google : "paint sealer for furniture"
Tell her to start stripping
pgh13
Midlands UK
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Would it be worth giving them a wipe down with some thinners or spirits first?
nelson_b
Contributor
http://www.zinsseruk.com/product/b-i-n/
not cheap - but widely available.
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Stain blocker available from most DIY stores in a handy spray can should make the surface inert and impenetratable it is about £5.00 per tin
Terryl
Custom built PC
Try using a compatible primer first, some paints are incompatible with others, example would be applying a lacquer finish over a latex or enamel base, this can cause problems like she is having.
Using a good quality primer can fix this in some cases.
pgh13
Midlands UK
Sounds like a serious medical condition...
Unless you of course can live with the effect and perhaps make a quid or two. What colour is it? ;-)
Well, it gives a not unpleasant effect but not the effect that's required. I think it must be red pigment in the original finish, but, as I said, I'd have expected it to be unaffected by water based paint going on top. It's intended to be white but is coming out as off white with yellowy streaks
If your wife doesn't think stripping is appropriate, a couple of streaks might be in order.
pgh13
Midlands UK
I hollered up at Ethel, I said, "Don't look, Ethel!"
But it was too late. She'd already got a free shot.
Grandstandin', right there in front of the home team.:-ohmy
