Trust
- Jul 18, 2004
- Age
- 77
- 1.8 m CM at SMR 1224 + Elev. with 7 lnb changer Ku (lin - circ) - Ka (lin - circ) C (lin - circ)
- Nijmegen Netherlands
For a heavy dish with several lnb's at a diseqc rotor , its hard working to bring it back from a far east or west position .
To help the rotor doing that , the STAB rotor has a system with spring inside .
I've never seen such system in any other rotor , so I thought about making that for the Moteck type rotors .
Made a kind of drum around the elbow pipe with a steel cable , two pulley's and two springs with adjustable tensioners .
Started with a empty SG2100 , just with the main shaft , with equal tension the elbow shaft is on zero .
The springs are pre-tensioned to keep the cable on the drum when turning to the other direction .
To keep de drum fixed to the pipe , I made two shells that kept in place by replacing the M8 X 50 pipe bolt by a longer one , and covered by a piece of alu pipe .
For the final test I have to buy a longer steel cable and put back the motor and worm in the SG2100 .
Will do the test with the CM 1.2 and the 5 lnb revolver and noticing the current turning with and without the spring assistant .
If its working OK I will it also make at the Twoteck .
