- UK
were the RJ10 straight through and wires going to same place on both sides of the RJ10's
Look at the wiring on the Duet cable and then the BT plug, compare that with the adaptor and then you can figure out what RJ10 - RJ10 you need.
I don't require a RJ10 - RJ10, its either an adapter for the 431A end, or a suitable Glensound replacement cable sporting RJ10 and RJ11 ends.
