New Channel 20 Mediaset Italia
mikeisyou
Feed Hunter
England
20 mediasat is active & FTA via multi-stream on my SX-88:)
I tried to scan it in but it did now show the new channel name so I deleted all the channels on 5 west transponder12669 H 35000
Now scan in the new channel line up via antenna settings:-
Select in this order:-
Multistream = On
Mode = TP
Search =OK
Now you will see 20 mediasat & the rest of the channels on this transponder :):Y
Unfortunately the SX88 does not overwrite the new channel name.
mikeisyou
Feed Hunter
England
Multistream = On
Mode = TP
Search =OK
Now you will see 20 mediasat & the rest of the channels on this transponder,
Unfortunately the SX88 does not overwrite the new channel name. :):Y
When I did a scan I found that the SX88+ deleted Rai News 24 and also reordered about 15 channels. The problem with scanning is even worse on the 12.5w multistream channels, some channels show no picture or show the wrong channel completely.
vaz23
20 Mediaset
London
Tomorrow a new channel will be launching called 20 Mediaset, it will be available on 5w Atlantic Bird and on Hotbird 13e encrypted via the Tivusat and Sky Italia packages. Its first broadcast will start at 19:30 with prematch build-up of the Juventus - Real Madrid clash.
Available on 5W 12669 H 35000 (SD) and 13E 11432 V 29900 (HD)
This channel replaces Retecapri.
Con Juve-Real nasce "20", il nuovo canale gratuito di Mediaset dedicato a film e serie tv - Tgcom24
Hello,
Can you help me with this channel 20 Mediaset please?
Nalleman
Motala Sweden
Sweden
Hello,
20 Mediaset is only available FTA on Eutelsat 9B on the Italian spotbeam which is centered over Italy which means you can't get it in the UK.
You can't get it on 5W anymore!
The encrypted version (Tivusat and Sky Italia) is on Hotbird 13E.
vaz23
20 Mediaset
London
So you mean it`s not possible to watch this channel in UK now please?
Nalleman
Motala Sweden
Sweden
The signal from Eutelsat 9B on 12149 V is focused on Italy so if it's possible at all to get it in the UK you would need a very big dish!
As for reception from Hotbird 13E a subscription is necessary. These are aimed for the Italian market only.
You can buy an official Tivusat receiver and pre-activated card for under £200. No ongoing subscription required but you must make sure it is already activated. You'll also need a dish pointed at Hotbird 13°E.
Nalleman
Motala Sweden
Sweden
Wasn't sure if I should mention that option here. Beware Tivusat are currently shuting down the oldest cards not sold together with an official Tivusat decoder or CAM.
If you choose the card and CAM option your receiver needs to cope with CI+.
vaz23
20 Mediaset
London
Thank you for this information
But I use to watch this 20 Mediaset last month, so without Card I can't get it please?
Nalleman
Motala Sweden
Sweden
No free to air is it only on Eutelsat 9B on a beam with a tight focus on Italy.
Don't know if someone here on the forum located in the UK has tried to get it with a big dish?
20 Mediaset used to be free to air on Eutelsat 5 West which is much easier to get in the UK but unfortunately it left this satellite last month.
I've not actually tried Italian beam since XtraTV left from the reused frequencies on the Nordic beam. South East England will offer the best chances for reception.
@moonbase did you try it at your location?
vaz23
20 Mediaset
London
Ok thanks
vaz23
20 Mediaset
London
Try what please?
vaz23
20 Mediaset
London
They anyone can give me the football satellite please?
rodscha
i check "programmi" it s half-old US series such as these: ok for expats too far from Astra 2!
I guess lots of Italian ads spread all over...Buon appetito!
Chicago Med IV​
14:14 - 14:59​
BLINDSPOT IV​
14:59 - 15:45​
BLINDSPOT IV​
15:45 - 16:39​
ALL AMERICAN III​
16:39 - 17:32​
ALL AMERICAN III​
17:32 - 18:27​
THE FLASH V​
18:27 - 19:22​
THE FLASH V​
19:22 - 20:13​
Chicago Med IV​
20:13 - 20:36​
THE BIG BANG THEORY IX​
20:36 - 21:04​
vaz23
20 Mediaset
London
Chicago Med IV​
14:14 - 14:59​
BLINDSPOT IV​
14:59 - 15:45​
BLINDSPOT IV​
15:45 - 16:39​
ALL AMERICAN III​
16:39 - 17:32​
ALL AMERICAN III​
17:32 - 18:27​
THE FLASH V​
18:27 - 19:22​
THE FLASH V​
19:22 - 20:13​
Chicago Med IV​
20:13 - 20:36​
20:36 - 21:04​
Ok, thanks a lot.
