LateAdopter
- Mar 26, 2018
- Age
- 78
80cm fixed, 4 position switch
28.2 E, 19.2 E, 13 E, 5 W
Xoro HRS8500, Edision Primo
- Berkshire
Can you try recording Talkingpictures on your on your 15gb usb with FAT32? Talkingpictures has about the lowest bitrate.I should have included this in my original post but as you can see the folders are there from the failed recordings but they are all empty. I'll keep trying to see if I can get it working.
I tried it on an 8gb stick with 4gb free and it recorded OK.
I think the problem is that the PVR and media player just quit, if there is a buffer overrun or underrun, rather than stuttering.
I tried using the media player to play back an old sample from 3sat SD, which has a high bitrate, from the 8gb stick. The first time, it played a couple of seconds and then quit. The second try played OK, but what it had read the first time would have still been in the cache. Even higher bitrate HD will play, from the stick, with other players.
