- Jul 26, 2003
- Location
- Scottish Borders
- Scottish Borders
No satellite passes due atm so Ive started playing with pager decoding. Exactly the same setup as for the wxsats but with one different bit of software -- PDW 3.12
Late at night the pager system isnt very exciting to say the least! a few test messages and one marginally more exciting one that says words to the effect "fill in the tick box"!!!!!
Screengrab of the test messages
PDW isnt difficult to set up - in the recording options set your vb cable in the soundcard option. The tricky bit is finding active pager datas in amongst all the other electromagnetic shash the antenna picks up! Have a look around 153MHz - that seems quite active
