Gsat 83 East
Mohd Sadoon
240 cm PFA - 180 cm PFA - 120 cm PFA
Coverage 14W - 125E
Oman
Gsat 83 East India beam in south Oman
1.8 m dish with Fuji lnb
Kypros_Pambou
TBS:6985,6925,5925usb
5 Pace&Arris IPTV Gateways
Greek Cyprus
Reception of Tata Sky Package with 3.4m.
Satfaca
Melmac (46N, 14.5E)
Melmac
Success in the 10.95-11.20 GHz range, and some 2dB short to lock in 11.45-11.70GHz range. Horizontal is almost as non-existant.
Satfaca
Melmac (46N, 14.5E)
Melmac
Very hard to tell for us far away, such off-footprint reports can only be confirmed by someone from the spot or very near by. But generally there's a pretty good chance to get the signal with 3m & over. The main question remains what would you do with the signal? Do you have access to subscription? All channels are encrypted.
ZazaiSat
Gothenburg
Gothenburg
No problem about the subscription, I can get subscription and it’s not a big deal but first is to get the signal And so u think with 3m dish could get the signal?
Satfaca
Melmac (46N, 14.5E)
Melmac
No idea, I am some 1600 km from you so ... it's pure guess.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
@ZazaiSat I am not sure did I try it. And, unfortunately, I do not have a possibility to do it ATM :(
Here's what I get in my area from this position with a 1.50m antenna.I'd like to think that if I used a 1.80 dish I could lock at least one transponder.Of course this is wishful thinking.But I console myself with the fact that in the C band I get many transponders with this antenna even with this antenna.
ZazaiSat
Gothenburg
Gothenburg
@ocean04 hej buddy can u try on this please with ur 3m?, I’m going to order one Big dish soon but would be nice if u can do a try of Gsat 83 Tata sky in Finland?, to see if 3m would be enough to get Good signal or would require more than 3m dish?
ocean04
Vaasa
Western Finland (63N 22E)
83.0E is not visible for me (trees in front)
It's also very low angle, I don't think it's possible in Sweden..
ZazaiSat
Gothenburg
Gothenburg
Ok and once I get my 3m dish then will give a try on Gsat 83 Tata sky beam if I can get it here in Gothenburg if not with 3m dish then I will try on Amos 4 at 65.0°E Nepal beam
Woah - you are getting in front of yourself. Are you optimising the dish for Ku or C-band? Twin band lnb's are a trade off in performance on one or the other band, so unless you want to be swapping lnb's back and forth or constructiong some crazy Heath Robinson lnb rotator system you really need to be concentrating on one band..
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
I would advise that you check with local planning regulations before buying anything
