Pipedream
Sheffield
gap30
technomate 90cm dish
Liverpool
How far are you prepared to go? £262 now
... Not wise to disclose what your prepared to go up to on here .... TJ's example for instance.
Pipedream
Sheffield
At that price the dreamers will have left the field, this could be a bloodbath !
With it not being motorized it's not going to be worth too much more, I would say £350 to £400 will buy it.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
If you have dish than it can be always motorized by standard or specially made mechanism. But if you have any motor or polar-mount then you still can not make dish for it. So, dish is primary, motor- secondary.
saj1985
Dreambox 800HD SE, Dreambox 500S, Skybox F5S, 90cm Solid Dish, Tm2600 Motor, Inverto Black Ultra LNB! :)
Lost...
it was £301 now itas gone back down to £262, so someone mustve withdrawn their bid
btw i got no idea how to withdraw bids on ebay
saj1985
Lost...
what would you need to motorise that 2.4m cm dish?
RimaNTSS
N-E from Riga
I see at least 3 options:
- Old good H-H AJAK motor (not in the production anymore);
- self-made polar-mount with 36' heavy duty actuator;
- Az-El-Skew mount (also self-made).
saj1985
Lost...
thanks for that,
im not good with diy so wont be able to make anything myself lol
RimaNTSS
N-E from Riga
You better get this 2.4m CM dish and then, for sure, you will find the way of motorization.
Pipedream
Sheffield
saj you are a feed hunter why would you want to be stuck on one sat for?
saj1985
Lost...
no if i get the dish and i will want to make it motoriezd
Off the shelf dual axis slew drive similar in principle to the one "st1" linked to. Heavy wedge needed, they are not cheap for a dish of this size and weight, start thinking in bags of sand.
or
Fabricator to make custom polar mount from scratch using box section, steel plate and flange mounted bearings
or
Existing polar mount that can be modded to accept the dish
In all instances, the motorisation is going to cost more than the dish on the assumption the dish goes for a monkey or less.
Agreed, any more than £400 and it is getting out of the bargain zone and into buyers remorse territory. It's a channel master dish, not a Precision, if it were a Precision 2.4m dish the tongues would be hanging out and the wallets getting unbuckled ready for stratoshpheric action.
saj1985
Lost...
or
or
Existing polar mount that can be modded by a fabricator to accept the dish
thats true thats why i do think ill end up getting it because it would be out my budget plus having to get it motorized
If you can afford the dish and you like it and the missus is OK with it then go for it.
One possible other consideration is, are you going to bother with local authority planning consent or mount it on a mobile platform or just install it and take a chance nobody complains about it?
If the price gets too far beyond your budget or what you can realistically afford then leave it and move on to the next one. There is always another day and another dish. They pop up now and again so at some point there will be another one on eBay even if you do not get this one.
saj1985
Lost...
yea i think im going to move on and leave this one
no im not worried about people complaining because theres loads of dishes up around my area
