For Sale [ITALY] I sell A TDT sat decoder - Spain -
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
I hope it is the right place.....
With this decoder you can get all SD channels of digital terrestrial Spanish as long as you have a satellite dish (1 meter at least) on Hispasat 30 west, with 19 channels including:
The 1
The 2
Tve clan
Tve teledeporte
Antena 3
La Sexta
Neox
Nova
LaSexta
Nitro
Telecinco
Cuatro
Divinity
Energy
Boing
Disney Channel
Gol
and teledeporte
all subtitled and with original sound.
I ask 120 euros and shipping at my expense.
Greetings
Available to send videos to confirm that it works.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Unusual really.......we can receive between 80 - 90 TDT tv and radio channels here (naturally depending on your location in Spain)...all of which are free and include all those you have listed.
All the actual tv's have a an inbuilt tuner/receiver so no need to buy anything. If you do fancy an independant receiver then they are readily available from under €20 and upwards.
¿If read correctly I assume the receiver you are placing for sale is a basic TDT receiver?
Anyway, best wishes to yourself. :Y
Mod note: moved to correct section
Pierangelo
Italy
No, this is the original televes TDT sat sold (the hd version) for more that 350 euro.....
Please inform you before......
I USE IT IN ITALY TO WATCH THE SAME TVs YOU GET IN SPAIN......
Try in uk, if you can
:p
Tururu
Assembled with recycled parts
Recycled as the owner.
Ebay.- TELEVES-5113-ZAS-COMBO-Receptor-satelite-recepcion-canales-TDT-hispasat-CARAVANA
It is not a normal receiver, it is satellite+TDT ==>Televes.
In theory is for users of Spain in Spain without a DTT signal to be in areas without signal from the terrestrial repeater and using a satellite link from the Hispasat, if I remember correctly ==> there are only SD channels.
A few years ago, they were sold as pre-authorized churros (without authorization) from many European websites to ride boats and caravans
No es un receptor normal, es de satelite+TDT ==> Televes.
En teoria es para usuarios de españa en españa sin señal de TDT al estar en zonas sin señal del repetidor terrestre y usando un enlace via satelite del Hispasat, si no recuerdo mal ==> solo hay canales SD.
Hace unos años, se vendian como churros pre-autorizados (sin autorizacion) desde muchas web europeas para montar en barcos y caravanas
mariust5
Cristor Atlas 100HD , motorised 1.1 Triax on Stab H-H
hastings , uk
Any photos of the box please ? Is it SD or HD ?
Pierangelo
Italy
Only SD, sorry.
In pm, I can send you a video.
The box works well.
A dear friend of mine, has his "Hermano" working is Spain.....
No internet needed! only a satellite dish pointed at Hispasat, 1 meter is more than enough in Italy.
I have no more the original box, but I have the manual.
