New Gibertini 1.5 Dish
Archive-8
@John @scopus how did you mount the cctv camera?
Above the dish looking down towards the lnb’s or on the lnb boom arm looking up towards the lnb’s?
Please, many thanks.
Yes, the boom arm right near the dish face looking towards the changer and LNB's
... only just come back in from band rehearsal Chris, i'll dig some install pics out in the morning for the two different methods i used for the Gibby & the 2.2 PF
Archive-8
Thanks guys I have ordered a camera and I have a spare input on my cctv dvr.
I will get the cable sorted out over the next few days.
Ok, both cameras used on 2.2 mtr & 1.2 Gibby are 1080p TVI type cameras using the coax cables installed years ago. The 2.2mtr one uses a micro pinhole type and is housed in a waterproof box behind the reflector and just needed a 1/4" hole in the reflector for the lens to see through, and the Gibby one is a micro ball type. Really really useful additions.
..........................................................................................................................................................................................................................................................................................................s-l1600.jpg2.2mtr 1080p pinhole dish cam ... reduced....jpg1.2 Gibby dish cam -- reduced...jpg1.2 Gibby dish cam ... reduced..jpg2.2mtr dish cam rear....jpgs-l1600.jpg2.2mtr 1080p pinhole dish cam ... reduced....jpg
Archive-8
..........................................................................................................................................................................................................................................................................................................View attachment 117648View attachment 117649View attachment 117650View attachment 117651View attachment 117647View attachment 117648View attachment 117649
The one I have ordered is similar to the white one in your photos.
Looks like a couple of zip clips should hold it on the boom arm unless I can find something more suitable.
Thanks for the photos as this has really helped me out:Y
Archive-8
Today I made the lnb cables up for fitting on the dish tomorrow.
Also run the motor cable plus camera cable across the garden in some conduit. I still need to seal the ends on the conduit.
Hopefully I will get the jack wired tomorrow and the last couple of f-plugs will get fitted.
Then I shall be able to check I have it on arc or not.
Archive-8
Connected the lnb’s up to the diseqc 1.1 switch today, my Dr hd d15 is now my positioner for the lnb Changer.
I didn’t get the chance to connect the jack up today, so that will be a job for tomorrow.
The ku lnb is a twin output Invacom 1 side goes to the motor of the lnb changer the other side goes the the other feed in through the diseqc switch.
My 1.5 dish is giving a signal on 1°W for tonight. I might try c-band if the bbc feed is still live @John @scopus or @Feedsat_DXer could you check please?
.. Bare with
0.8 west - 3984 R. BBC feed is 9dB with me at the moment Chris
Edit: .. I posted my reply just before yours Chris, no problem- i can check it tomorrow when you want.
Archive-8
The oven is on and I have the tm5302 just need to find an hdmi cable long enough.
Archive-8
Does anyone know a good supplier of the stab diseqc 1.2 positioner
Or is this a good price?
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F302312930008
Link doesn't open here.
TJ had a Stab rotor - with an internal fault, but under the suppliers warranty.
Trust
Nijmegen Netherlands
At Satshop24.de also available
Grab the one from Chris Chris lol ... we both use one of those for lnb changer control and they have fitted the bill just right.
