My go at WXSAT
Terryl
Custom built PC
What you guys need is a combination of a Hi-pass/Low-pass filter, but they would have to be very sharp.
We used what was called a digital brick wall hi/low filter, the combination of the two filters would be very tight, the low-pass would let everything up to 138.5 MHz through, and the hi-pass would start at 136.5 MHz and everything above that, the overlap after the combination would be about 2 MHz wide.
The big draw back was the $1200 price.
Archive-8
At that price I will put up with the black bars :eek:
pontiend
Contibruter
south yorkshire
I am only looking at the bits between the black lines.:)
Ive had an idea to extend the window of opportunity of the NOAA's. Lets see if it works - the theory is good but............
pontiend
Contibruter
south yorkshire
This is this mornings scan NOAA 18 Northbound 41W MEL 13W 137.9125.
Poor signal at the bottom.What seems to happen is that the satellite signal has all but gone when the recording is about 90%I think that some of the problem is that the houses block the signal at the Northbound start/ Southbound End of the pass.I have shoved the Antenna up about four foot That may Help a bit.The houses are near on south facing.
pontiend
Contibruter
south yorkshire
The raised antenna looks to looks to be an improvement not as much signal fade at the end of the recording.I need to see the same improvement in the next recordings if so I will fasten it there permanently.It would be nice if I could get it up on the corner over the gutter I recon that it would do well there.Unfortunately it is not likely to happen I am not safe up ladders now.One can dream though can't one.:)
Terryl
Custom built PC
Looks like you got it.
Terryl
Custom built PC
Here is the latest pass from NOAA 18, West Coat US on 4/28/18 at 0930 PDT
Looks like Northern California might get some rain.
pontiend
Contibruter
south yorkshire
Still not bad all northbound though I have to wait until tomorrow for the southbound ones.The precip ones on this pass are not good though
This is NOAA 15 66E MEL 3 E long 17:27 UTC.
pontiend
Contibruter
south yorkshire
NOAA 15 again.24 W MEL 21 W Long.precip images fine this time round.
Finished now until tomorrow .
pontiend
Contibruter
south yorkshire
Some interference on this one.Not getting the recording problem now though.
NOAA 18 30E MEL 16 E LONG 07:27:17 UTC.
The next one is NOAA 15 32 W MEL 16 W LONG 08:30:29 UTC.I will see what that one looks like..It looks like brollys needed down south.:)
pontiend
Contibruter
south yorkshire
I said in the other thread not long back that I only get clean scans on low East scans .
wrong I do sometimes get good ones on higher East scans.
this is NOOA 18 Northbound 25E Mel 18E Long 17:31 UTC.
Though I only got one enhanced scan.
Archive-8
Nice picture :Y
Is that a layered picture? If so I will have to find the command line to add it in to my pi setup.
pontiend
Contibruter
south yorkshire
No it is just the full image from the WXtoimg image folder Chis.
pontiend
Contibruter
south yorkshire
I have not been getting very good scans from NOAA 18 lately.I have only been getting the west scans.( I forget to change the frequency.:))I could do with an automatic frequency changer but where would the fun be then.:).There is a 18 East pass at 17:34 UTC must try to get that one
This scan from NOAA 18 is from a West pass quite a good one too..It must have gone between the houses.
NOAA 18 Southbound. 51 E MEL 10 W LONG.09:20 UTC.
pontiend
Contibruter
south yorkshire
Got the 17:34 UTC scan only just though.
NOAA 15 was scanning at 17:25 UTC.
NOAA 18 was due at 17:34 UTC time enough to change the frequency I thought .Wrong the N15 enhancements were still going on at 17:34.
WXtoimg started scanning NOOA 18 on the wrong frequency I stopped it pronto change the frequency to the correct one restarted recording,got a good scan of NOAA 18.
Who's a clever boy then.Well me this time it dose not happen very often these days.:D
NOAA 18 Northbound 25 E MEL 18 E LONG 17:34 UTC.
pontiend
Contibruter
south yorkshire
I missed that one Chris I was down the garden.It was at 4 W here 20;12.
The West passes are the ones where the houses get in the way.Some worse than others.
Archive-8
In your pictures you hardly have any interference :Y
Are you using any pre-amp/filters?
pontiend
Contibruter
south yorkshire
No I just use the home made antenna.With the software running on windows 7.I do get pagers sometimes.
The rear of the house is North facing.On the West passes I get low signal interferance at the start of northbound scans and at the end of southbound scans
Edit below are two scans from NOAA 18 one East and one West
