Eurosport 4K will also be available on Sky and Virgin for Roland Garros too.eurosport 4k will be use hd plus plat forma and
canal plus france
I tried both FRANSAT ULTRA HD DEMO and DEMO 3 after a blind scan on 5w. Both came up as encrypted.what freq?
what freq?
I have a Fransat Cahors receiver and it does will not scan in the UHD channels, probably because it not 4K.Eutelsat 5w
12732 V 29950
Encrypted in Viaccess, its free to view via Fransat card
I am unable to get any signal on that transponder on the GB UHD 4KRoland Garros Tennis on France-2 HD & France-4 HD Multi-Stream 11509 H 29500 is Free to Air with audio on the Edision Primo S2
88cm dish gives me 86% Signal Strength 100% Signal Quality.
I am not that familiar with it either so just going to try the VU Zero 4K to see if that works.You need a Multi-Stream satellite receiver like the SX-88+ or the one I use Edision Primo S2,
I am not familiar with the the GB UHD 4K ? can you give more details.
I believed the VU Zero 4K was multi-stream but mine is not. Maybe its a driver issue.I am not that familiar with it either so just going to try the VU Zero 4K to see if that works.
WOS state different.I have read through the spec for your device & it does not support multi-streams tv,
http://vuplus.com/manual/Vu+ ZERO 4K User Manual_180116.pdf
